Vitara piston help
Old Jun 9, 2009 | 10:54 AM
eg:R's Avatar
Default Vitara piston help
which side does the arrow suppose to point. crank side or distributor??
Old Jun 9, 2009 | 12:18 PM
Radyjr's Avatar
Default Re: Vitara piston help
on vitara d-series builds. the piston arrows are faced to the front of the motor toward the crank pully side.........
Old Jun 9, 2009 | 12:46 PM
dez6's Avatar
People have run them both ways. I have them pointing towards the crank pulley, "JFK" as well as "FJT" I believe ran them this way and made 400+hp with no problems. Everything that I read now shows that people who run them pointing toward the flywheel experience less of the diesel chug noise commonly associated with these pistons.
Old Jun 9, 2009 | 01:36 PM
eg:R's Avatar
cause i have them pointing toward the crank and the valve relief seem to be bigger for the exhaust side. so i was planning to turn it to the flywheel side and have the bigger valve relief for the intake valve. anyone notice them bigger so am i seeing things?
Old Jun 9, 2009 | 01:40 PM
dez6's Avatar
Thats what some say..http://www.turbod16.com/viewtopic.php?f=3&t=39440
Old Jun 9, 2009 | 01:49 PM
fast2camciv's Avatar
the arrows point to the timing belt side.
Old Jun 9, 2009 | 02:02 PM
VTECJUN's Avatar
The arrows on the Vitara pistons point to the flywheel. The wrist pin offset and the valve reliefs are correct when they are installed that way.
Old Jun 9, 2009 | 02:08 PM
wilham320's Avatar
THIS IS CORRECT...
although I built my 76mm vitara before this was realized, and my arrows are toward the t-belt. I don't have any noise at all.
Old Jun 9, 2009 | 03:12 PM
eg:R's Avatar
ok will be pointing the piston to the flywheel
Old Jun 9, 2009 | 03:34 PM
Garage 808 Hatch's Avatar
mine point towards the flywheel, runs great, 350whp nonvtec.
remember, on the grand vitara the exhaust and IM are in opposing locations to hondas in respect to the trans location.
Old Jun 9, 2009 | 04:12 PM
mine was pointed towards the timing belt (i just looked at pics to confirm) and it was quiet and made 405whp...honestly i dont think it matters, i dont remember the wrist pin being offsett.
Old Jun 10, 2009 | 05:44 PM
dez6's Avatar
and the debate continues...
Old Nov 6, 2009 | 01:06 PM
bowtiecity's Avatar
Installed my the same way....Should be running in a month......
Old Nov 6, 2009 | 01:41 PM
da_dude's Avatar
Either way will work as they both been proven.
Old Nov 6, 2009 | 02:05 PM
NonovUrbizniz's Avatar
Loved
Either way will work the "correct" method is to have the arrows pointing to the Flywheel.
this way both the valve releifs are in the correct position and the very minor wristpin offset is correctly oriented.
Again either way will work.
EJ8CIVIC
Aug 25, 2011 06:41 PM
obuhmyuh
10
Feb 5, 2008 12:41 PM
DarkBB4
Apr 1, 2005 06:10 PM
90crxmike
Mar 14, 2005 03:20 PM
Maddox
Feb 29, 2004 07:24 PM
