vband
Old Dec 15, 2007 | 02:46 AM
Pompiuses's Avatar
Default vband
Perhaps a noob question, but what's the advantage of running vband vs conventional flange?
I often see conventional turbo flanges loosening themselves after a while, will vband help with this?
Old Dec 15, 2007 | 02:48 AM
DaveF's Avatar
Default Re: vband (Pompiuses)
ive never had a v band come loose. they use a lock type nut on them, and i cant complain how much easier everything is to work on/ & fab.
Old Dec 20, 2007 | 10:11 AM
Pompiuses's Avatar
Does vband flanges come in 3"? I was told by a shop that if I want vband on my turbo and downpipe it have to be 2.5".....?
Old Dec 20, 2007 | 10:23 AM
Mikey3000's Avatar
the main advantage is ease of service. 1 screw instead of 3 or 4.
Old Dec 20, 2007 | 12:14 PM
b18bturbo's Avatar
Default Re: vband (Mikey3000)
vband housing come in various sizes from most common are 2.5 3.0" and 4.0" vbands most housing are going to be 3" vband
Old Dec 20, 2007 | 12:25 PM
OMG B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">Does vband flanges come in 3"? I was told by a shop that if I want vband on my turbo and downpipe it have to be 2.5".....?
Depending on what kind of room you have you can weld a 3" vband directly to your turbo housing. As far as the shop goes. Maybe there is no room for a 3"?
Old Dec 20, 2007 | 12:56 PM
DANinja's Avatar
another "noob" question...
are there any turbos that are v band compatible by default or does the hot side of the turbo need to be swapped out?
seems to me v band setups would generally be prone to leakage but I don't have any personal experience with them so who knows.
Old Dec 20, 2007 | 01:34 PM
SIXTY-1HATCH's Avatar
Default Re: (DANinja)
you can run v band on anything if you have the room. My turbo comes with a 4 bolt, and they make a conversion from the 4 bolt to 3" v-band. It's ALOT easier to work on.
Some turbos come with them, usually the larger turbos it's standard b/c they run larger downpipes. I run a full 3" exhaust and when you tear down motors alot the v-band conversion is nice cuz it's alot quicker, and they never come loose like the bolt flanges
Old Dec 20, 2007 | 03:10 PM
b18bturbo's Avatar
Default Re: (SIXTY-1HATCH)
most of the new precision turbos are going the vband route thy have them on the sc61 sc50 and few othr models now.
atp alos makes a stg 3 t31 vband housing
Old Dec 21, 2007 | 08:23 AM
Default Re: (b18bturbo)
Thats who i got mine from, couldn't remember, atp makes all different size conversions check em out
Old Dec 21, 2007 | 06:33 PM
akira712's Avatar
If you cant get the vband hot side you can always have your fab guy do it for you
Old Dec 23, 2007 | 08:58 AM
blue2000em1's Avatar
Default Re: vband (akira712)
Correct me if I am wrong.But don't they also sell a adapter that allows you to run a vband on a 4 bolt or 5 bolt??????
SlowSOHC-T
Apr 22, 2007 07:20 PM
Topdawgg
Dec 30, 2005 07:46 PM
CiViC SiR
Nov 23, 2005 06:58 AM
ineedhelp
Welding / Fabrication
16
Jul 29, 2005 01:06 PM
Kwuaymaikrup
Oct 30, 2003 09:07 PM
