Valve springs
Old Dec 17, 2012 | 02:32 PM
  #26
Boyle.R's Avatar
Default Re: Valve springs
Originally Posted by TheShodan
I would then recommend to use the GSC valvetrain to go with those cams that you plan to use next year. I also recommend an oil that has a higher ZDDP content (Zinc) for the engine itself. The weight isn't so important as the zinc content for those camshafts. I do not know your location as to whether or not you're in the U.S. or not, so I cannot provide an accurate list of oils for your availability.
Not is U.S. I can get this stuff to mix in with my oil, good idea or bad idea? any negative effects on turbo using zinc additive?
http://www.ebay.ie/itm/LUCAS-RACE-EN...item3a73ff2205
Old Dec 18, 2012 | 05:17 AM
  #27
tepid1's Avatar
Zinc additive is ok. No ill effects on anything. It's a lubricant.
I like Brad Penn or even ZR1 works well.
Old Dec 18, 2012 | 01:34 PM
  #28
Boyle.R's Avatar
Is the added zinc beneficial to your engine's bearings?
Old Dec 18, 2012 | 03:47 PM
  #29
tepid1's Avatar
I know it's critical when running big cams with aggressive ramp rates and heavy springs. I don't use it for engine bearing reasons.
Old Dec 18, 2012 | 05:00 PM
  #30
Boyle.R's Avatar
I found this which is available to me in the UK
http://www.frost.co.uk/zddplus-anti-...-additive.html
Any use?
Old Dec 18, 2012 | 05:25 PM
  #31
TheShodan's Avatar
Moderator
Any use?
As stated in your thread, we don't typically add ZDDP to our oils, we just get the right oil so it has the proper amounts in it. I've seen some of these in Manchester, but if still not available, I'm sure that could work, just make sure you know the amounts you need.
http://store.forcedperformance.net/m...otor%20Oil.pdf
89efhatchy
Mar 12, 2014 08:49 AM
xjdmjunkiex
Jul 15, 2012 10:45 AM
State.of.Prime
Oct 17, 2010 01:43 PM
civic00sir.
Mar 19, 2010 09:59 AM
B16Civic93
Feb 22, 2005 03:05 PM
