Valve seat damaged?
Old Mar 12, 2010 | 09:47 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Valve seat damaged?
Car in signature developed a dead #2 miss out of the blue, has fuel, has spark, has good compression, has less than 3% leakdown... I found that the #2 exhaust valve lash was zero, no feeler would fit whatsoever. The others were within spec. I tried to loosen the tight one, and backed the screw until it stopped, and still, no clearance!? WTF bad valve seat or something?
Old Mar 13, 2010 | 05:59 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: Valve seat damaged?
up
Old Mar 13, 2010 | 07:28 AM
5thgen's Avatar
the cam lobe wasn't pushing the rocker when you measured it, was it?
I don't know....it doesn't make sense to me because compression/leakdown came out good. Maybe try taking the manifold off and looking down the port.
Old Mar 13, 2010 | 08:16 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
I honestly wouldn't have thought of looking through the exhaust... mani has to come off for the head to come out anyway, so ill have a peek. Thanks.
anyone else?
Old Mar 13, 2010 | 11:30 AM
5thgen's Avatar
You could take a plug out and shine light through the spark plug hole and watch through the port while you turn the motor. If its sealing like you say though, I doubt you'll see light.
Old Mar 13, 2010 | 09:01 PM
ludeboy22's Avatar
Its possible but IMO if everythings in spec I'd pull the head to further inspect.
i had an intermantent missfire and the next day it was a dead cylinder turned out to be the valves
thank god the no piston damage was done
dbsharp
Engine Machining & Assembly
Nov 3, 2016 05:41 PM
jalenda9
Jun 21, 2016 01:46 PM
hatchback19
Apr 20, 2003 08:51 PM
se93
Mar 31, 2002 10:25 AM
se93
Mar 29, 2002 06:05 PM
