What does changing the valve seat angle do to performance?
Old Mar 29, 2002 | 02:55 PM
se93's Avatar
Default What does changing the valve seat angle do to performance?
I saw that the Prelude Type S cylinder head has a 45 degree valve seat angle instead of the regular non-S spec H22a's, which have a 60 degree valve seat angle. How does this work better?
Thanks,
Mark
Old Mar 31, 2002 | 07:11 AM
G's Avatar
G
Default Re: What does changing the valve seat angle do to performance? (se93)
It would allow the valve/seat clearance to open faster with less lift. If you have a steep angle, there is still the top of the valve and lower portion of the seat to deal with. With a shallow angle, the top of the valve and bottom of the seat aren't as close to eachother at the same lift levels as the steeper angle. A picture would reveal much more, I just don't have one.
The negative effects of the shallower seat is less area for the valve to cool/seal against the seat. Good for NA, bad for turbos. Then again........ I'll take good low lift flow any day....
Old Mar 31, 2002 | 07:18 AM
se93's Avatar
Default Re: What does changing the valve seat angle do to performance? (G)
Thanks. Sounds interesting. I will probably have it done.
Regards,
Mark
Old Mar 31, 2002 | 10:25 AM
G's Avatar
G
I am pretty sure that valve work is among the more important aspects when head porting is done.
dfoxengr
Jun 20, 2006 05:05 PM
XBoostedAccordX
Sep 29, 2003 05:01 PM
se93
Mar 29, 2002 06:05 PM
