valve lapping leak test
Old Oct 20, 2012 | 10:22 AM
boostedteg4dr's Avatar
Default valve lapping leak test
what is acceptable when doing a leak test?
No leak at all?
a few drops?
Old Oct 20, 2012 | 12:52 PM
13g-crx's Avatar
Default Re: valve lapping leak test
none. Do a valve job and call it a day.
Old Oct 20, 2012 | 05:36 PM
none. after a 3 angle valve job is done they wont leak at all?
Old Oct 20, 2012 | 06:20 PM
wantboost's Avatar
Who is Mr Robot?
nope
Old Oct 20, 2012 | 08:52 PM
Muckman's Avatar
Moderator in Chief
Have your machine shop check for valve wobble too. Poor valve seal can be caused by worn valve guides.
Old Oct 20, 2012 | 09:11 PM
wantboost's Avatar
Who is Mr Robot?
I could see valve wobble causing issues when the valve is open but with the valve closed under full tension from the valve spring it seems like to me it screams valve seat/valve wear
Old Oct 20, 2012 | 09:22 PM
Muckman's Avatar
Moderator in Chief
It happened to me with my new head. Had .003" side to side wobble. Hammered the valves out of round because they arent square in the seat.
Old Oct 20, 2012 | 09:29 PM
wantboost's Avatar
Who is Mr Robot?
ah, yea now I can see how valve wobble would cause the valve to hit the seat at a goofy angle making it wear funny
Old Oct 21, 2012 | 06:56 AM
when the chamber is full of water there is no leak....
when I fill it with fuel it leaks......
Old Oct 21, 2012 | 10:21 AM
13g-crx's Avatar
The head is already off. You need to lap the valves at a bare minimum. You can get a lapping tool and compound for a DIY project at autozone. Its simple.
Old Oct 21, 2012 | 10:33 AM
nealnanoHX's Avatar
You want no leakage at all.
Old Oct 21, 2012 | 10:39 AM
rich7777's Avatar
X2 exactly....
Old Oct 21, 2012 | 12:36 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Water is thicker then fuel.
Old Oct 22, 2012 | 02:14 PM
probably good enough. any blow by would probably be about the same that is getting passed the rings at 600hp
Old Oct 24, 2012 | 04:07 PM
checked the valves with the proper vacuum tool. exhaust were mediocre and intake were bad. the intake were the ones that leaked a bit.
doing a vale and seat grind. it wont leak at all after thats done.
if it does ill post again.
protopro88
Oct 24, 2019 04:50 AM
bb4socal
Nov 18, 2006 07:02 AM
IntegraB18
26
Dec 18, 2005 06:53 PM
all motor b20b
Sep 17, 2004 08:50 PM
