valve adjustment for b16 head w/ gsr cams....for the b16 or the gsr ???
Old 06-01-2004, 03:32 PM
Rod.'s Avatar
Default valve adjustment for b16 head w/ gsr cams....for the b16 or the gsr ???
I am about to start valve adjustments on my b16 head wtih gsr cams. Which one do I go for b16 specs or gsr specs. I searched and nothing cam up with what I am looking for. Thanks
Old 06-01-2004, 03:44 PM
pb16b's Avatar
Default Re: valve adjustment for b16 head w/ gsr cams....for the b16 or the gsr ??? (redturbocivic)
b16...
Old 06-01-2004, 03:48 PM
Turbo E's Avatar
interesting question...id follow the cam's origins which are the B18C
EDIT: aren't they the same?
Old 06-01-2004, 04:32 PM
99B16Si's Avatar
what are u guys talking about theyre both the same specs:
.006-.007 intake
.007-.008 exhaust
Old 06-02-2004, 08:17 AM
Turbo E's Avatar
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">what are u guys talking about theyre both the same specs:
.006-.007 intake
.007-.008 exhaust</TD></TR></TABLE>
thats what i figured
Old 06-02-2004, 08:38 PM
JDM_Honda_Fiend's Avatar
U should follow the lash spec for the cam and not the head. Because these are stock cams the adjustment values are the same. .006/.007 should be good.
Old 06-02-2004, 08:50 PM
Rod.'s Avatar
Default Re: valve adjustment for b16 head w/ gsr cams....for the b16 or the gsr ??? (JDM_Honda_Fiend)
Thanks everyone, I got it done and it was simple
Old 06-02-2004, 09:30 PM
TwoK4drSi's Avatar
Let me tell you it's a difference btw night and day. I know a lot of people who just drop it in but do the adjustment. Worth the time and money if you have someone doing it. I did a valve adjustment and shot my compression 30 psi! The gsr pulls very hard in a b16. Definitely worth the cam upgrade
Old 06-03-2004, 06:12 AM
99B16Si's Avatar
if your compression went up from a valve adjustment your valve lash had to be tight as hell
Old 06-03-2004, 07:34 AM
TwoK4drSi's Avatar
I heard a slight clicking from my engine so I wanted to be safe. I didn't know it'll shoot up that much. I really don't think cams would raise cylinder compression
Old 06-03-2004, 09:44 AM
99B16Si's Avatar
unless theyre way too tight and arent able to close all the way
Old 06-03-2004, 11:47 AM
TwoK4drSi's Avatar
*shrugs*
d16turbocoupe
12
08-29-2010 10:33 PM
soon2bdropped
32
07-24-2007 11:03 AM
VTEC_Du_Ma_Mai
07-20-2007 05:03 PM
speedchoppy209
07-21-2006 07:28 AM
brinks
07-12-2002 06:21 AM
Quick Reply: valve adjustment for b16 head w/ gsr cams....for the b16 or the gsr ???
