VAFC hack, open downpipe, obdII..... possible??
Old Sep 1, 2002 | 06:56 PM
matt0199's Avatar
Default VAFC hack, open downpipe, obdII..... possible??
for some reason i have a feeling that this wont work because of the sensors before and after the cat....
or am i missing something? will the vafc hack work just as well if i run open downpipe?
Old Sep 2, 2002 | 05:55 PM
matt0199's Avatar
Default Re: VAFC hack, open downpipe, obdII..... possible?? (matt0199)
anyone????
Old Sep 2, 2002 | 06:36 PM
speedymon's Avatar
I just installed my drag 3 w/ open dp. I'm throwing a code 41 on my 96 gsr. Primary o2 something. I can't tell what it drives like cause the open dp shakes the car and is too loud. But my AF gauge reads rich all the time. I think i'm dumping too much fuel.
Old Sep 2, 2002 | 06:40 PM
matt0199's Avatar
Default Re: VAFC hack, open downpipe, obdII..... possible?? (speedymon)
and you're using the vafc hack?
your car is obdI isnt it?
i was planning on running open wastegate / open downpipe like this guy on prelude online.... but i dont know how he did it with the vafc hack and obdii
Old Sep 3, 2002 | 10:26 AM
matt0199's Avatar
Old Sep 3, 2002 | 10:31 AM
Ri5e's Avatar
If your running Open downpipe and the Primary O2 sensor is close to the edge of the pipe, its gonna run real shitty...
2nd O2 sensor tripping off due to OBdII will not put the ECU into limp mode but it'll just have a check engine light to tell you that 2nd o2 sensor is "bad" or "missing in action"
Old Sep 3, 2002 | 07:59 PM
speedymon's Avatar
Default Re: VAFC hack, open downpipe, obdII..... possible?? (CRV Monster)
Cool thanks. I wrapped my 2nd O2 in foil and it has tripped off a CEL. Only the primary o2 is acting up, but it's close to the end of the DP. 3" exhaust coming soon.
Old Sep 3, 2002 | 08:57 PM
liam821's Avatar
Open exhaust is awesome on a turbo honda. I can done it many times on my car, although im obdI. I have a friend, drag kit on a obdII civic running the afc hack, he let another friend barrow his CAT so he could pass smog. It got a CEL because of the 2nd o2 sensor. You can get a o2 sensor simulator which should fix that problem...then things will be happy.
liam
Old Sep 4, 2002 | 10:15 AM
matt0199's Avatar
Default Re: VAFC hack, open downpipe, obdII..... possible?? (liam821)
sweet thanks
so my ecu wont try to mess things up? just give me a cel and thats it?
B18C1CYA
Jun 24, 2003 09:31 AM
kHoA DoGG
Oct 25, 2002 09:20 AM
Unjockable
Aug 3, 2002 05:27 PM
senpai
Apr 22, 2002 06:31 AM
