VAFC Hack Dyno?
Old Jul 7, 2002 | 08:13 PM
TurBoXBirD16's Avatar
Default VAFC Hack Dyno?
As people were discussing about the VAFC hack, which only uses DSM 450 cc injectors with a upgraded fuel pump,
no missing link or check value nor FMU
It sounded great so far for everybody
but is there anybody that is going to go to the dyno and see how much power it made??
Because VTC_CIVIC has dynoed his civic at 6 psi with HONDATA and got something like 180 WHP, i want to see if the VAFC can get close to this
it would be good if VTC_CIVIC can go dyno his car using the VAFC hehehe
if anybody has done it, post numbers please
thanks
Old Jul 7, 2002 | 09:02 PM
M.A.R.C.'s Avatar
Default Re: VAFC Hack Dyno? (xbird)
if ya wait about a month I'll have a dyno up for you. I'm going to be running the v-afc/injectors hack on my setup (T3 60trim, .60a/r, .48 a/r turbine) but i'd only be boosting like 6psi or whatever the .45bar ends up being after pressure drops. I am thinking about dyno tuning it just to get it running nice. Like I said though... probably not till like mid august I would have that done.
Old Jul 8, 2002 | 06:34 AM
98civicEX's Avatar
did it 2 months ago...here you go
https://honda-tech.com/zerothread?id=173063
the actual pics are at this site...
http://forums.civicland.com/viewtopi...t=2986&start=0
[Modified by 98civicEX, 3:37 PM 7/8/2002]
Old Jul 8, 2002 | 07:28 AM
M.A.R.C.'s Avatar
Default Re: VAFC Hack Dyno? (98civicEX)
oh yah i remember that post. I'm going to be running that v-afc trim/450cc/walbro setup also but with a t3 60-trim. I'm wondering if my numbers would be much higher than a tdo4-15g at the same boost level. The tial w/g i'm gonna be running is a 6.5psi spring so I'm guessing like 5-6psi with pressure drop. I was thinking I could pull something like 160whp at this level. Does that sound realistic?
Old Jul 8, 2002 | 07:58 AM
98civicEX's Avatar
Default Re: VAFC Hack Dyno? (CivicRyda2k)
i would easily think so, isn't that the super 60 turbo? best t3 you can get?
Old Jul 8, 2002 | 08:03 AM
VTC_CiViC's Avatar
Actually, I think thr Super 60 is a T4.. I may be wrong though. T3 should spit out a good 170ish whp at 6psi with the AFC-mod. Probably 190ish on Hondata
Old Jul 8, 2002 | 10:37 AM
M.A.R.C.'s Avatar
Default Re: VAFC Hack Dyno? (VTC_CiViC)
Yah i think there IS a T3 super 60 also... not sure but. The T3 I have is pretty good sized. David... so you think 170whp at 6psi is a realistic figure huh?
"what did u make at 6psi again?"
EDIT: don't worry it's 183whp i remember
[Modified by CivicRyda2k, 2:38 PM 7/8/2002]
Old Jul 8, 2002 | 11:25 AM
c1hatch's Avatar
i dyno'd at 213hp @ .5bar throughing a CEL
i was very, very lean from idle to about 5700 rpm.
b18c1
max rev kit
dsm 450
stock fpr
[Modified by c1hatch, 1:15 PM 7/8/2002]
Old Jul 8, 2002 | 11:39 AM
M.A.R.C.'s Avatar
Default Re: VAFC Hack Dyno? (c1hatch)
max rev kit
dsm 450
stock fpr
motor? b16a?
Old Jul 8, 2002 | 01:33 PM
nice #s
i want to see some STOCK boost or 6 psi dyno numbers
i mean hondata can make 180 whp at 6 psi, can a VAFC get close?? like 160?? or 170??
with the greddy kit intercooled fuel pump injectors VAFC
Old Jul 8, 2002 | 02:57 PM
M.A.R.C.'s Avatar
nice #s
yeah i would like to see some ACTUAL numbers also. Though I think likely numbers would be around the 160-170whp range i think
Old Jul 8, 2002 | 07:51 PM
i hope we can get 160 whp just with the VAFC,
i think we can coz i think hondata is making 20 whp more
if this is so, i don't think it's worth the money for a hondata if boosting only under 10 psi
i mean at 160 whp to 200 whp range, it is not hard to get 20 whp
once u get into like 300 whp or up, 20 whp is hard to get, and that's the time hondata kicks in for that 20 whp, and that's the time hondata is worth the money
just my 2 cents
how much does a GSR hybird civic I/H/E make on the wheels??
or a SI civic make? I/H/E?
Old Jul 8, 2002 | 08:50 PM
RoaringTurtle's Avatar
New User
yeah i would love to see a dyno with no boost spiking
i dyno'd 172 whp and 165 tq at 8.5 psi
this is without vtec, d16y7
and a 12:1 fmu with a walbro 255lph fuel pump
i think those are some fairly good numbers from an fmu setup
no tuning at all
but i think i can make a bit more from a vafc hack setup
well not think, i hope
Old Jul 8, 2002 | 09:34 PM
Default Re: VAFC Hack Dyno? (RoaringTurtle)
that's still a nice numbers at 8.5 psi
i thinku would gain around 10 to 20 whp using that vafc??
i would love to see some numbers
Old Jul 8, 2002 | 10:00 PM
shermanyang's Avatar
anyone got a LS/turbo running a VAFC hack? numbers? and how did you program the VAFC?
Old Jul 9, 2002 | 07:08 AM
VTC_CiViC's Avatar
Typical I/H/E B18C1 makes about 155-160whp, B16A2/3 around 145-150whp
Old Jul 9, 2002 | 08:37 AM
thanks
are u selling all ur turbo stuff ?? i have seen it on partstrader.com
Team 4
37
Apr 23, 2009 11:39 PM
S2KP
Aug 20, 2003 01:07 PM
ActiveAero
Mar 3, 2003 11:58 PM
SamC
Oct 19, 2001 04:48 PM
