VAFC 2.5 bar map settings
Old Oct 14, 2005 | 02:03 PM
flood's Avatar
Default VAFC 2.5 bar map settings
Just installed the 2.5 map and burned a chip with crome for it. However the VAFC is still hooked up but its messing with the signal (I think). What settings can you use on the VAFC for the 2.5 map?
Thanks!
i know it should be disconnected, but its bling bling n' stuff.
Old Oct 14, 2005 | 02:12 PM
splitime's Avatar
Default Re: VAFC 2.5 bar map settings (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">i know it should be disconnected, but its bling bling n' stuff. </TD></TR></TABLE>
Just disconnect it
Otherwise, I think you can just zero out ALL the settings and basically make it a light show.
Old Oct 14, 2005 | 02:18 PM
flood's Avatar
Default Re: VAFC 2.5 bar map settings (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
Just disconnect it
Otherwise, I think you can just zero out ALL the settings and basically make it a light show.</TD></TR></TABLE>
Well it is zero'ed but the lightshow is cool. There are settings floating around for a 3bar GM but I haven't found the 2.5bar settings.
I could disconnect it but I wanted to try first.
emotionisdead
Sep 1, 2005 02:28 PM
Pssst!
Apr 19, 2005 05:45 PM
reditr
Jun 8, 2003 04:01 AM
