Vacuum manifold question
Old Apr 26, 2005 | 08:59 AM
  #26
Huee's Avatar
Default Re: Re (dennis)
Self tapping screws
Old Apr 26, 2005 | 09:05 AM
  #27
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis &raquo;</TD></TR><TR><TD CLASS="quote">It's the 1/8" NPT hose barbs for your accessory's vac/boost source (wastegate, blow off valve, etc...). You probably don't need 6, but I just ordered extra in case I ever needed them. Order as many as you need, just make sure you have enough of the 1/8" hex plugs to fill the holes you're not using.</TD></TR></TABLE>
Oh, okay, got it... I don't know why I couldn't figure that out... thanks!
Old Apr 26, 2005 | 09:31 AM
  #28
dennis's Avatar
Default Re: Re (Huee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huee &raquo;</TD></TR><TR><TD CLASS="quote">Self tapping screws </TD></TR></TABLE>
If I was going to drill through something thick, like say a shock tower, then yes, self tapping screws get a thumbs up, as you'll be there all day w/o them.
The tip of the self tapping screw is just under the diameter of the threads, and every time you take them in and out, there's a good chance you catch and remove a little more metal. Eventually, you'll just have to drill another hole.
...just giving an explanation of what I experienced when I used to do alarms and stereos
Old Apr 26, 2005 | 12:51 PM
  #29
_Cyclone_'s Avatar
The screws I'm trying to use now are not self tapping, and they don't want to thread into the holes I drilled very much.
I got the McMaster.com 4-port distribution box with 1/4NPT ports instead of 1/8NPT ports... I already had the 1/4NPT barbed fittings. I only got four, and I'm only going to need three... I don't see the use for six.
Old Apr 28, 2005 | 08:28 PM
  #30
99sonicbluegsr's Avatar
here is mine
Modified by 99sonicbluegsr at 5:53 AM 4/29/2005
Old Apr 29, 2005 | 04:15 AM
  #31
_Cyclone_'s Avatar
Default Re: (99sonicbluegsr)
Pic didn't work dude. I'm going to post a pic of mine momentarily.
Old Apr 29, 2005 | 04:41 AM
  #32
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99sonicbluegsr &raquo;</TD></TR><TR><TD CLASS="quote">here is mine file:///C:/Documents%20and%20Settings/rich%20higgins/My%20Documents/My%20Pictures/2005-04-28/100_0174.JPG
Modified by 99sonicbluegsr at 5:53 AM 4/29/2005</TD></TR></TABLE>
You can't link to a file on your hard drive. You have to upload to a host somewhere. I've used :
http://www.we-todd-did-racing.com/
They are free and work with H-T, but have a limited amount of space.
You can also get your own hosting account for about $5/month if you want to host more stuff. I use:
http://order.1and1.com/xml/ord...tatic
If you want to make your image work right now, just e-mail it to me and I'll host it.
Old Apr 29, 2005 | 08:42 PM
  #33
_Cyclone_'s Avatar
Default Re: Vacuum manifold question (CycloneBlue_1.6EL)
Yeah, I'm slow. Here is the box now.
I went to CTR and bought a couple of stainless #8 self tappers, 1.75" long. They worked like a charm in the holes I drilled in the firewall for the previous screws. The old screws weren't working because they were chrome plated brass. Got the AVCR sensor installed too, I'll have one extra port after I get the BOV installed when I put the turbo on the weekend after next.
Old Apr 29, 2005 | 09:22 PM
  #34
hotrex's Avatar
cost me around 2 dollars to make, some barbs a piece of 5 inch pvc and some jb weld.
oh yeah..... this is hmt blingin"
Old Apr 29, 2005 | 09:27 PM
  #35
rmcdaniels's Avatar
Default Re: (hotrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrex &raquo;</TD></TR><TR><TD CLASS="quote">cost me around 2 dollars to make, some barbs a piece of 5 inch pvc and some jb weld.
This wins, I like it better than my setup.
Old Apr 29, 2005 | 09:52 PM
  #36
hotrex's Avatar
Default Re: (rmcdaniels)
it doesnt cost money to be baller, rmc you get my drift.
if i actually took my time to make this it woulda came out h-t style
well maybe h-t style if i wrote jdm type r on it.
bottom line is it was near free and it works as good if not better than the golden eagle
Old Apr 30, 2005 | 04:04 AM
  #37
_Cyclone_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrex &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt cost money to be baller, rmc you get my drift.
bottom line is it was near free and it works as good if not better than the golden eagle </TD></TR></TABLE>
Exactly. Function over form. The only reason I got the one from Mcmaster Carr is because I needed to order a couple of BSPT fittings from them, and my total was like $2, so I added that thing. I was actually about 1/2 way done making one using a piece of 1x1 steel railing that we use at my work. I had the ends welded shut and the holes drilled, hadn't tapped them or painted yet. Now it's a paperweight, oh well.
Old Apr 30, 2005 | 09:02 AM
  #38
EJ1 wilcox's Avatar
Kick ***! I'm making one just like this today! Saweet!
vietnogi
Jun 18, 2005 05:10 PM
DENCIO
Jul 21, 2004 07:16 PM
junbb1
Jan 12, 2004 06:36 PM
downpipe
Sep 1, 2002 08:59 PM
