Vacuum manifold question
i dunno about your car, but on my del sol right by the vin # on the firewall. there is 2 threaded holes that have plugs over them. they both nearly line up perfectly with the holes on my golden eagle vacuum manifold. just gotta take a dremel and bore out the hole a bit and you could bolt it right to those two holes. check next time you have a chance.
Yeah, I have the threaded holes too, but my manifold is slightly smaller than the GE. I might be able to get one in there, but I'd have to drill out the manifold to accept a bolt that big.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dennis »</TD></TR><TR><TD CLASS="quote"> Just used some drywall screws I had laying around...</TD></TR></TABLE>
Tacky.
Tacky.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">vac manifolds = mess
much cleaner than having vacuum tees all over the place IMO
</TD></TR></TABLE>much cleaner than having vacuum tees all over the place IMO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboaddict »</TD></TR><TR><TD CLASS="quote">
much cleaner than having vacuum tees all over the place IMO</TD></TR></TABLE>
oh ya, i dont even consider those an option either. I just dont like seeing all the extra hose everywhere. especially the huge one you guys feed the manifolds with. personal preference, they all work fine im sure.
Is this one from McMaster Carr? That's where I got mine from. Do the screws you put in it hold it tight to the firewall? The screws I put in mine thread in a little bit, but stop threading and leave the manifold loose. I think I'm going to try and find some self tapping screws.
I guess they would take a while to rust anyways... and when they start, just replace them. I'm going to attempt this method and post a pic of my results... I have to address my oil leak at the return fitting first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">Is this one from McMaster Carr? That's where I got mine from. Do the screws you put in it hold it tight to the firewall? The screws I put in mine thread in a little bit, but stop threading and leave the manifold loose. I think I'm going to try and find some self tapping screws.</TD></TR></TABLE>
Yes, mcmaster carr, just like dustin's I believe. My screws went right through the holes and threaded into firewall. Just don't over tighten or you'll strip the thin metal in the firewall.
Personally, I wouldn't bother with self tappers on the thin firewall metal, they strip the metal easier - this is from experience.
FYI:
McMaster.com DIY vacuum manifold:
quantity / part # / description
6 44555K131 Brass Double-Barbed Tube Fitting, Barbed X Npt Male For 1/4" Tube Id, 1/8" Npt
1 44555K133 Brass Double-Barbed Tube Fitting, Barbed X Npt Male For 3/8" Tube Id, 1/4" Npt
1 5469K151 Aluminum Distribution Manifold, 6 Outlets, 1/4" Npt Inlet X 1/8" Npt Outlet
1 50785K22 Med Pressure Extruded Brass Thrd Pipe Fitting, 1/4" Pipe Size, Hollow Hex-Head Plug
4 50785K21 Med Pressure Extruded Brass Thrd Pipe Fitting, 1/8" Pipe Size, Hollow Hex-Head Plug
FYI:
I think I'm going to order and make a McMaster.com DIY manifold. Just one question, I can figure out what all the parts are except this one:
Can you explain which part this is and why I need 6 of them? Thanks!
It's the 1/8" NPT hose barbs for your accessory's vac/boost source (wastegate, blow off valve, etc...). You probably don't need 6, but I just ordered extra in case I ever needed them. Order as many as you need, just make sure you have enough of the 1/8" hex plugs to fill the holes you're not using.
