vacuum leak?
Old Mar 16, 2003 | 08:29 AM
extrmeboost's Avatar
Default vacuum leak?
well i have some sort of a leak under my hood, it seems to be coming from under the intake manifold, and its really loud. the car will idle at about 1200 rpm or so and drop to about 800 after a few seconds, after that its a pretty stable idle, so im really confused as to what it is. im also not getting full boost, im assuming its due to the same thing, im hitting about .34 bar when i should hit .45 bar and im tired of all these stupid little problems making my car slow. sorry for the long post
Old Mar 16, 2003 | 10:04 AM
Default Re: vacuum leak? (extrmeboost)
no help?? im about to just pay a tech to figure it out, cuz im tired of it.
Old Mar 16, 2003 | 10:33 AM
TurboCX's Avatar
Yes, this could be a vacuum leak. If you can hear it, than follow the sound and hear where it's coming from. This should be a simple fix. Find the leak and repair it. A hose could've simply slipped off or ripped off. I don't mean too sound mean, but it sounds like a simple fix. You already said that it's coming from the intake Manifold so you solved half the problem. Now just reinstall or replace the hose. Good luck!
Old Mar 16, 2003 | 10:37 AM
Default Re: vacuum leak? (TurboCX)
not that easy, or it would be fixed already. it sounds as though its coming from underneath the intake manifold, as in UNDER it where i cant see, and i dont know what lines run under there so im not quite sure what to do, i have had several people look at the car already and noone could figure it out because the car is not acting like it has a vacuum leak, the idle is fairly smooth, it doesnt surge, im going insane, my head will soon explode
Old Mar 16, 2003 | 10:49 AM
inspyral's Avatar
The cruise control vac line runs behind the IM, toward the bottom...
Old Mar 16, 2003 | 10:57 AM
Default Re: vacuum leak? (inspyral)
nope checked that, ok you know the hole in between the 2nd and 34d runners on the mani, sounds like its somewhere down in there, but i just cant find it.
_Tim
14
May 9, 2009 03:30 PM
darkstar1440
Nov 11, 2006 01:57 PM
ekcivic9
Feb 8, 2006 11:42 AM
suprmods
Jan 4, 2006 12:10 PM
extrmeboost
Mar 18, 2003 09:36 PM
