Vacumn FI engine need some advice...
Old Sep 24, 2006 | 10:42 PM
calvinPGMFI's Avatar
Default Vacumn FI engine need some advice...
Engine specs:
B16a2 84mm CP pistons 9.1:1 CR
Darton Sleeves
Eagle rods
Oem bearing
CTR cams
Victorx Manifold
BBK 70mm TB
No FITV
Full-Race mani
Skunk Valve spring + retrainers
62-1 Turbo
Tail BOV
Tail WG
MSD directly on my ecu(no ignitor, dizzy only for sensors)
My Software/Rom with gear Electronic boost controller(GM solenoid)
SRR cam gears
Other things...
My problem is as followed:
Idle vacumn: 390-420 mBar
By accident(inch -> mm convertion)
I gapped the intake valves to 0.15 inch and exhaust to 0.17inch.
I bought an new valve clearance tool in the USA. I'm used to mm and not inch.
But my vacum was good after this mistake: 280-290 mbar.
I readjusted my valves to 0.15mm/0.17mm and my vacumn is 380-414 mbar again.
My cam gears or 0/0, I didn't have time to go the dyno yet.
My compression numbers: 182-179-178-184(warm engine)
One other thing i noticed: If i start the engine cold(in the morning) My vacumn is less then when the car is fully warmed. Cold start +/- 424 mbar
warm 380-390 mbar.
My car drives better then with the b16 81mm. Spools much faster. If I increase the idle to 1500 rpm my vacum goes to 304 mbar.
I don't know what could cause such a low vacumn, is this a problem?
I triple check all vacumn lines and verything.
Modified by calvinPGMFI at 10:32 AM 9/25/2006
Old Sep 24, 2006 | 11:37 PM
1158's Avatar
390 to 420 mb is in the range of 10 to 12 in/hg, which does seem to be a little low, but I'm comparing this to what my basically stock GSR was pulling before I started the turbo install. I don't know what impact the CTR cams will have.
If it runs and drives good I would think it's ok. Sorry I can't help out more, maybe someone else can chime in.
Old Sep 25, 2006 | 12:21 AM
Default Re: (1158)
thanks. On autometer it show 16-14 inHG.
Old Sep 25, 2006 | 12:31 AM
1158's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinPGMFI &raquo;</TD></TR><TR><TD CLASS="quote">thanks. On autometer it show 16-14 inHG.
Even better
Old Sep 25, 2006 | 12:32 AM
Default Re: (1158)
so problem or not?
Old Sep 25, 2006 | 12:45 AM
1158's Avatar
I would think there is no problem, but again I am not an expert. Hopefully someone else can confirm. What makes me think it's ok is the car runs/drives good and doesn't smoke.
Just an FYI, but I was seeing in the range of 18 to 22 in/hg before I started installing the turbo. I'm not done yet, so I can't say if it has changed. I'm curious what others using the CTR cams see.
Old Sep 25, 2006 | 08:38 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Vacumn FI engine need some advice... (calvinPGMFI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinPGMFI &raquo;</TD></TR><TR><TD CLASS="quote">Engine specs:
I gapped the intake valves to 0.15 inch and exhaust to 0.17inch.</TD></TR></TABLE>
if they are gapped that loose, you need to start there.
the inch spec is 0.006 - 0.007 intake
and 0.007 - 0.008 exh
if thats how they are set up, they are way loose.
Old Sep 25, 2006 | 10:56 AM
Kelly.'s Avatar
I've quit using this account
is this a fresh motor?
i was seeing ~12 inHG when i first started my motor, but after breaking it in im seeing 17 in/hg
Old Sep 25, 2006 | 11:30 AM
Default Re: (Kelly.)
fresh motor. I'm seeing 16 inch now sometimes 18 inch.
I made a mistake inch/mm. But i have set them good now
Old Sep 25, 2006 | 01:15 PM
Kelly.'s Avatar
Default Re: (calvinPGMFI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinPGMFI &raquo;</TD></TR><TR><TD CLASS="quote">fresh motor. I'm seeing 16 inch now sometimes 18 inch.
I made a mistake inch/mm. But i have set them good now</TD></TR></TABLE>
16-18 is good in my book
Old Sep 25, 2006 | 11:15 PM
oke
kaleb.honda.si
Sep 9, 2015 09:56 PM
kaleb.honda.si
Sep 8, 2015 11:59 AM
mattie_96
Mar 11, 2006 04:24 PM
Bluj40
Dec 29, 2005 09:52 PM
RABBIT9
Apr 22, 2003 02:13 PM
