Vacum source?
Old Oct 22, 2002 | 08:19 AM
legendboy's Avatar
Default Vacum source?
Should I run my external wg vacum source from my brake booster or the compressor housing? 9-12 lb spring. thanks
Old Oct 22, 2002 | 09:26 AM
echo999's Avatar
New User
Default Re: Vacum source? (legendboy)
compressor housing if you don't want to overspool your turbo. (max pressure gen will be wastegate spring)
brake booster if you want to make sure you get your 9-12lbs at the manifold..
(instead of having a pressure drop through the FMIC and seeing 8-12lbs at throttlebody)
hondamyheart
Jun 20, 2018 09:57 PM
R.A.T.
Oct 8, 2008 06:53 AM
the.hamburglar
Aug 1, 2005 07:27 PM
96ex
Jun 30, 2005 05:33 AM
InTeGrA B18b1
Jun 21, 2003 02:34 PM
