Using OEM B-Series conrods for a turbocharged application..normal to do?
Old May 8, 2019 | 10:13 AM
sdenton8's Avatar
Default Using OEM B-Series conrods for a turbocharged application..normal to do?
Anyone run ls rods on oem pistons with boost? Can you post up what your setup is? Im looking for ideas
Old May 8, 2019 | 11:19 AM
Aradin's Avatar
Premium Member
Default re: Using OEM B-Series conrods for a turbocharged application..normal to do?
Pretty much anyone with a stock bottom end turbo LS or LS/VTEC has...
If you're inquiring about stuffing them in a D series, skip it and put some aftermarket internals in it. D series internals are stupid cheap.
Old May 8, 2019 | 11:50 AM
Txdragon's Avatar
Plus, won't work in a D without major modifications.
Old May 8, 2019 | 12:11 PM
sdenton8's Avatar
Yes i should of put ls rods in a d16. I have a set that i got for free thats already machined and bushed for d16. So i was thinking they are good for 300hp, why not shoot for 300. Or atleast 250. But not sure if the oem pistons can handle it.
Old May 8, 2019 | 12:13 PM
Txdragon's Avatar
If that's the case, your next problem is that OEM pistons are press fit.
Old May 8, 2019 | 12:14 PM
sdenton8's Avatar
Ls rods are press fit arent they?
Old May 8, 2019 | 12:18 PM
Txdragon's Avatar
But the small end bushings you install to make them work with D16 pistons are for free floating pins.
Old May 8, 2019 | 12:23 PM
sdenton8's Avatar
I was unaware of that. I always thought they was setup for oem pistons.
DaX's Avatar
DaX
Loved
Community Favorite
You got the LS rods for free...that should tell you about their value today. As stated, a set of forged Eagle rods are cheap enough so that I doubt you'll find many people using modified LS rods in D16 builds any more.
You may be OK @ 250 hp on OEM cast pistons, but I wouldn't recommend it. You'll be itching to turn up the boost in no time, and may push past the limits of what the stock slugs can handle. It also depends on the tune - you're planning to pay a professional to tune it, aren't you? You're looking at about a $500 difference between cast and forged pistons - chump change in the grand scheme of building a turbocharged Honda.
Nonvtak monster
Oct 31, 2013 09:13 AM
ferio-ichi3
Sep 29, 2013 02:45 PM
duffmans92eg
Jul 21, 2006 03:05 PM
turbo sol
Aug 23, 2002 10:45 AM
