using 4 bolts on a 5 bolt dp flange.
Old Jun 26, 2004 | 10:09 PM
DubyaAye's Avatar
Default using 4 bolts on a 5 bolt dp flange.
i just fabbed my own full 3" dp and welded one of the holes up on the dp flange and was wondering will it leak air with only 4 bolts. this going on a sc61 with inlinepro ss manifold on a civic si with a/c.
Old Jun 26, 2004 | 10:23 PM
project dc2's Avatar
Default Re: using 4 bolts on a 5 bolt dp flange. (DubyaAye)
as long as you get the 4 bolts in tehr egood it shodult leak. it shoudl be all good. also dp looks good .
Old Jun 26, 2004 | 11:55 PM
turbopimp's Avatar
Kinda hard to see from the pics, but if that 5th bolt can still sit flush against the flange, then you can use a Dremel tool with a small cut-off wheel and cut a slot on the flange. Then all you'd have to do is start the bolt onto the turbine housing first and then hook the DP flange onto the bolt, install the other 4 bolts and tighten.
Old Jun 27, 2004 | 06:29 AM
RotiEatter's Avatar
Ditto
Default Re: using 4 bolts on a 5 bolt dp flange. (turbopimp)
I am onlly running 4 out of 5 bolts on mine and it is fine. I am missing the same one you are. the way the DP was made there is no way i could fit it on there. No leaks or anything.
Old Jun 27, 2004 | 07:02 AM
HybridKOOP's Avatar
Default Re: using 4 bolts on a 5 bolt dp flange. (RotiEatter)
Couldnt you guys put a stud into the turbine housing for that one bolt.. and just use a nut on it?
Old Jun 27, 2004 | 07:08 AM
RotiEatter's Avatar
Ditto
Default Re: using 4 bolts on a 5 bolt dp flange. (HybridKOOP)
I am using studs on all 4 but if I put one in there it would hit the DP.
Old Jun 27, 2004 | 08:07 AM
This One's Avatar
you guys need this....
darkintegra
Apr 28, 2010 02:28 PM
Hump-Free
Oct 9, 2006 08:54 PM
boostincoupe
Aug 3, 2006 09:20 PM
huge230
Apr 25, 2006 08:49 AM
B18EG6
Feb 19, 2003 02:33 PM
