Help identifying this JRSC part
Old Feb 23, 2010 | 08:01 PM
Ldo's Avatar
Ldo
Default Help identifying this JRSC part
(not my picture)
Just bought a used JRSC kit and looks like I'm missing the above part. Can somebody tell me what it does?
Thanks
Old Feb 23, 2010 | 08:43 PM
slo97civic's Avatar
Default Re: Help identifying this JRSC part
looks to be the adapter that bolts in between ur fuel pressure regulator and fuel rail. u may need it due to clearance issues on the fuel return line. it rotates your fpr so the return line doesnt hit ur intake plenum.
Old Feb 23, 2010 | 09:04 PM
Ldo's Avatar
Ldo
I see. But if I'm not running the stock JRSC FMU, do I still need that piece? or that piece needs to be there regardless?
Thanks.
Old Feb 23, 2010 | 09:17 PM
nextproject97's Avatar
He is 100 % correct and if you have it I dont see why you wouldnt use it .I did not have that part when I got my jrsc at first and had to bend the return line on my regulator it worked but it sure was a close fit to my intake with the return line .
Old Feb 23, 2010 | 09:24 PM
If you click this link and look at the pic of my set up you can see how tight of a fit it was without the fpr adapter .I also have the LHT set up which probably didnt help . I have since installed the adapter .
https://honda-tech.com/forums/showth...14810&page=504
gotdc2
Sep 26, 2011 01:07 PM
vietxdragon
Mar 23, 2007 10:03 AM
88crxhfb16
Jun 5, 2005 04:01 AM
