URGENT RC Injector Question
Old Sep 9, 2003 | 10:16 PM
superduperman's Avatar
Default URGENT RC Injector Question
Hey guys. I just bought a set of 440cc RC injectors. Thing is, the color of the firing end is black unlike the usual silver that I see. I was curious to know if these types of injectors are not OBDI? Any help would be appreciated.
Old Sep 10, 2003 | 12:35 AM
Sonny's Avatar
Default Re: URGENT RC Injector Question (superduperman)
Do they look like this?
Your question re: are they OBD1? I assume you're asking if they are saturated (high impedance) or peak-and-hold (low impedance). Get a meter out and check the resistance between the contacts on the injector. If it's 12 ohms or more, they are high impedance (OBD1/OBD2). If it is 3 ohms or less, they are low impedance (OBD0).
Sonny
Old Sep 10, 2003 | 08:16 AM
Default Re: URGENT RC Injector Question (Sonny)
No they look like this:
So basically are you saying just as long as they're saturated, they're OBDI/OBDII compliant. And that peak and hold ver. of rc injectors are for OBD0? Cause I know the ones I have are saturated. Also I found out that the connectors used for these injectors are sqared bosch style. Is this still ok to hook up to my honda?
Old Sep 10, 2003 | 08:44 AM
VTC_CiViC's Avatar
Injectors aren't OBD-anything compliant.. they're either saturated or p/h. Only timr OBD comes into play is with the wire clip, but that's an easy bypass.
Old Sep 10, 2003 | 11:03 AM
Default Re: URGENT RC Injector Question (VTC_CiViC)
Im sorry but no one has yet to answer to my question. Basically do all RC injectors use OBDI injector connectors no matter what color the firing end is?
Old Sep 10, 2003 | 11:55 AM
quikB18B's Avatar
Unless something has changed recently Rc only makes an obd1 injector, For obd2 you just have to purchase the clips.
cvctypr
Nov 25, 2008 11:40 PM
AmauryR
Nov 15, 2007 09:46 AM
EJ8 GSR-T
Apr 26, 2006 06:33 PM
chris@allmotor.net
Oct 19, 2003 04:39 PM
