Upgrading t3/t04e compressor wheel?
Old Oct 10, 2010 | 12:07 AM
DC2BUD's Avatar
Default Upgrading t3/t04e compressor wheel?
Whats up, I have a Turbonetics t3/t04e 54 trim .63 stage 3 that i was thinking about upgrading too a t3/60-1. Is it as easy as having the compressor wheel swapped out with the 60-1 or do you have to machine the housing/backplate also?
Old Oct 10, 2010 | 03:10 PM
HiProfile's Avatar
Default Re: Upgrading t3/t04e compressor wheel?
It's a larger inducer and exducer, so it would require a new cover and backplate. If the 54trim is still good, I'd just sell it and buy a new 60-1. The individual parts and labor charges would be nearly as much, if not more.
Old Oct 10, 2010 | 03:20 PM
TheShodan's Avatar
Moderator
Exactly. Not to mention, for the 60-1, the stage III wheel is really a mismatch for that compressor wheel. you want to bump up to at least a Stage V or P-trim to do that. You would need to change back plates, compressor cover, internal bearing system (the one on the 54 trim has a lot to be desired). As HiProfile stated, by the time you do all that, you could sell your 54 trim, and use that money towards a proper turbocharger. Might even be something more advanced than a 60-1 depending upon your budget.
Old Oct 10, 2010 | 03:27 PM
Sinople1's Avatar
i have a 60-1 almost new forsale pm me if intersted!!
Old Oct 10, 2010 | 05:40 PM
DC2BUD's Avatar
Thanks for the answers guys, I guess ill sell it and get something else. The 60-1 came to mind cause my goals are 400whp, maybe more later, on a piston/rod GSR on a spoolin log with a 3" dp....so I know I'm gonna have to run more psi then I would with a nice ram mani.
Old Oct 10, 2010 | 06:02 PM
TheShodan's Avatar
Moderator
Not necessarily. The manifold isn't directly "psi" related. IF you're going to use one, then use one, but remember there are different configurations of the 60-1 that are available, you just have to look for them. The standard one has a bit left to be desired
Old Oct 10, 2010 | 06:38 PM
DC2BUD's Avatar
Whats a budget minded turbo you recommend for a daily driven GSR at 400whp?
Specs are
B18c1
9:1 CP pistons
Eagle rods
Supertech valves w/ s2 springs
Skunk2 pro intake mani
68mm Omni Power tb
Drag intercooler/piping
Hks bov
Tial 38mm
Spoolin log
3" downpipe
3" exhaust
Old Oct 10, 2010 | 11:00 PM
TheShodan's Avatar
Moderator
Depends upon what you mean by "Budget". you won't get anything new and quality for less than about $850
Old Oct 10, 2010 | 11:40 PM
DC2BUD's Avatar
Budget meaning something I might find used for under $600, cause I'm assuming I'm not gonna get much for this used 54 trim.
Old Oct 11, 2010 | 12:37 AM
TheShodan's Avatar
Moderator
A used T67 or SC61 Used. Won't get anything like that new. As for the Holset stuff, too much to integrate.
Old Oct 11, 2010 | 08:18 AM
DC2BUD's Avatar
SC61 sounds like the ticket for my goals and there's a lot of deals on them in the marketplace. Thanks
BOOSTIN1
Feb 18, 2006 07:18 AM
Del
Dec 31, 2003 10:44 AM
Quik Chris
Aug 11, 2003 08:23 AM
BoostedD15B7
May 15, 2003 07:19 AM
