Custom Top Mount
Old Oct 11, 2010 | 09:31 AM
TJChad's Avatar
Default Custom Top Mount
So i'm just starting to get my hands into some fabrication work. In the next month i'll start to make my own top mount manifold for my set up. It will be an EF chassis (check my sig). I'm looking for someone who has alot of good experience with this. The turbo i'm running is a Borg Warner S300sx-60 with a divided housing. My main question is with fabbing up the wastegates? Should I set it up to run dual 38mm's or combine the two sections and simply run one larger wastegate? I'm planning on pushing 20-30lbs of boost with my setup. Any help is appreciated! Thanks guys
Old Oct 11, 2010 | 09:39 AM
cleansi's Avatar
Default Re: Custom Top Mount
you may get more help in the fabrication forum,
but honestly with a divided housing and that turbo i would deff run dual 38mmWG's it might be more of a pain but it will be more efficient
Old Oct 11, 2010 | 09:45 AM
TJChad's Avatar
I'll shoot another post in there, Thanks bud
Nathan S
May 29, 2019 12:46 AM
1FASTHF
Nov 22, 2010 06:14 AM
TJChad
Welding / Fabrication
Oct 11, 2010 05:53 PM
crvtkllr
Feb 5, 2007 07:40 PM
xfrankx
29
Mar 1, 2006 01:03 AM
