upgrading a 57trim on a d16, what to get?
Old Oct 11, 2013 | 04:43 PM
RACEPAK's Avatar
Default upgrading a 57trim on a d16, what to get?
hi guys,
i sold my garrett 57 trim that i had on my built d16 (built head 3.6 cam, big im,)
didnt had any numbers yet, since i sold the turbo
i'm thinking gt3076 or a 5858 bb,
what do you guys think?
thanks
Old Oct 11, 2013 | 05:28 PM
Turbo-LS's Avatar
Default Re: upgrading a 57trim on a d16, what to get?
What's the power goal? That's a lot of cam for smaller turbos.
Old Oct 11, 2013 | 06:06 PM
GEN2 LS's Avatar
Loved
can never go wrong with the 3076R. Garrett>Precision
Old Oct 11, 2013 | 07:17 PM
a1320honda's Avatar
HP goals? I just tuned a built single cam (eagle/vitara, zex 35900)that made 544whp on a garrett 57 trim cold side and center section and bullseye exhaust wheel and housing on 110 fuel.
Old Oct 12, 2013 | 10:59 AM
Natural Aspirations's Avatar
That has got to be a reccord
Old Oct 12, 2013 | 11:07 AM
TheShodan's Avatar
Moderator
Possibly. Using a Borg-Warner 75mm turbine wheel will always give top end peak power, but the compressor wheel is begging for mercy.
Old Oct 12, 2013 | 11:19 AM
a1320honda's Avatar
Yeah, that was at 35lbs. Wouldnt make any more lol. made power up to 8500 then dropped like a stone. Took it to the track and before it exploded the single cam tranny, went 12.0 on 15lbs
Old Oct 12, 2013 | 01:22 PM
TheShodan's Avatar
Moderator
So, I'm rather confused. Are you saying that the next turbo you want to make more than 550whp, or within an efficiency range less than 35 psi but closer to 15psi of boost pressure.
Are you staying more street/strip or more strip.... No E.Ts please. A HP level of maximum boost pressure, an RPM limit and a budget (a maximum willingness to spend on turbocharger dollar amount range, please)
Old Oct 13, 2013 | 01:23 AM
a1320honda's Avatar
Not saying we want it to make any more HP. The only reason we stopped at 15lbs was cause the tranny exploded the diff. We didnt stop at 15lbs for any reason lol. Thats just when the tranny scattered. And working my way up to 544 hp, it wouldnt make any more on the next pull. We maxxed out the turbo. The last pull was 15hp less and AFR's were perfect and it was on 37psi. So with all being considered and the IAT's in the 120 degreee range, i took it as we were out of turbo. I took it what i feel was beyond the limits of the turbo at 650crank HP on a "57trim" and sotck sleeves on a single cam, so the owner wanted to stop. Backed it down and made another pull at safe levels and amde the nearly same 540hp. Good enough for us.
Old Oct 13, 2013 | 08:36 AM
TheShodan's Avatar
Moderator
I see... That's a bit better of an explanation. The turbine wheel had plenty to go, but the compressor wheel was at its edge. Its only 51lbs/min. that's as far as it can compress air. if IATs were getting over 130F* you know you're approaching max speed on the compressor.
So, let's try this again..
1-You want 650whp or crank hp?
2- an RPM limit
3- a budget (a maximum willingness to spend on turbocharger dollar amount range, please)
AFAccord
Sep 19, 2012 08:55 AM
tuhboek
Mar 2, 2010 02:19 PM
BlkTegOn18s
Jun 21, 2009 10:36 AM
pane93civhb
Mar 18, 2008 05:00 PM
ludelvr
Jul 30, 2003 09:08 AM
