Upgrading cams
Old Oct 12, 2013 | 08:17 PM
JHipps's Avatar
Default Upgrading cams
If i upgraded my cams from stock b16 cams to 97 ITR Cams. Would i need to do anything more than just put them on, redo timing and go? Would i have to do any type of valve adjustment?
Old Oct 12, 2013 | 08:27 PM
slowDB7's Avatar
Default Re: Upgrading cams
id say get it retuned
Old Oct 12, 2013 | 08:32 PM
Turbo-LS's Avatar
Well you would need to upgrade the stock valve springs to at least stock ITR valve springs. People have run them on b16 and gsr springs but I personally wouldnt. More lift more duration you need more spring
Old Oct 12, 2013 | 08:37 PM
efhatchbackracer's Avatar
^^ what this good fellow said! Dont run itr's w/o dual valve springs! They come with duals from the factory for a reason
Old Oct 12, 2013 | 09:09 PM
JHipps's Avatar
oh yea forgot to mention i already have a supertech valve train
Old Oct 13, 2013 | 08:37 AM
TheShodan's Avatar
Moderator
You'll need to retune, that's quite a change. Set valve lash to OEM specifications on Supertech, drive to dyno and retune. And yes, it WILL make a difference for the 1-2 hours you may be there.
KelownaEM1
Oct 4, 2012 05:11 AM
DAcraze
Jan 17, 2006 03:54 PM
dc5r2002
Jun 16, 2004 03:41 AM
fastfu
May 5, 2003 11:38 AM
