uneven plastigauge reading... please input!
Old Jun 29, 2013 | 07:25 PM
Mike Real's Avatar
Default uneven plastigauge reading... please input!
I've no idea what I am doing wrong or what this means. But when I plastigauge my rods this is the result I end up with. Think I need new rods? Or is this normal
Old Jun 29, 2013 | 08:18 PM
Muckman's Avatar
Moderator in Chief
Default Re: uneven plastigauge reading... please input!
Are you 100% certain the rod bore and bearing back are clean?
If so try a simple swap test:
First flip the rod 180* on the rod journal.
Does the squish change sides?
Yes = tapered rod bore
No = possibly tapered rod journal
Swap the rod to another rod journal.
Does the squish follow the rod?
No = tapered rod journal
Also swap the bearing and run the same test. You get the idea.
*I assume you dont have a micrometer or dial bore gauge or you wouldn't be asking.
Old Jun 29, 2013 | 09:24 PM
Mike Real's Avatar
What's the best way to remove the rod caps? I might be smearing the plastigauge while removing rod cap?...
I cleaned and retorqued with new plastigauge 3 times with same result. Then I flipped the rod 180 and the plastigauge reading evened out. Im certain that everything is clean. Thank you for responding!
Old Jun 29, 2013 | 09:32 PM
Orangevirus1's Avatar
yeah I'd also like to know this when I plastigauge my new bearings and crank.
the end caps are hard as hell to get off the Eagle rods, and Wiggling it back and forth like crazy is gonna mess the readings.
Old Jun 29, 2013 | 11:20 PM
JDMAF's Avatar
I just undue the rod bolts all the way thread them in about 2 threads then hit the bolts with a dead blow hammer... never smeared...
Old Jun 29, 2013 | 11:25 PM
famous323's Avatar
same method i use, works like a charm.
Old Jun 30, 2013 | 04:36 AM
blackeg's Avatar
same here, i actually keep the socket on the head of the bolts and hit the end of the socket.
also when you are tightening or loosening the bolts make sure to have the ratchet perpendicular to the length of the crank to help avoid the crank from rotating around
Old Jun 30, 2013 | 07:53 AM
Muckman's Avatar
Moderator in Chief
Yes exactly. You can only plastigauge on the TOP half of the rod big end (not the end cap) so when you hit the rod bolt to seperate the halfs you arent smushing the wax more.
Old Jun 30, 2013 | 07:55 AM
Mike Real's Avatar
Awesomee! Thanks for info!
5genhatch
Engine Machining & Assembly
May 27, 2019 08:48 AM
EG-SIXV-TEC
Jul 5, 2013 05:20 AM
geebs
May 17, 2007 10:41 AM
Mad Cow Disease
Oct 2, 2003 01:55 PM
Sonny
Aug 23, 2002 08:06 PM
