uberdata users
Old Jul 2, 2005 | 11:31 PM
95turbogsr's Avatar
Default uberdata users
I got a p72 ecu right now and i was going to chip it and run version 1.7 but i heard from a couple poeple back home that the p72 has problems with the knock sensor and i should go with the p28 is there any truth to this?
Old Jul 3, 2005 | 01:27 AM
Cloner's Avatar
Default Re: uberdata users (95turbogsr)
There is no truth to it.Use the P72.You can disable any sensor you want with uberdata.There is truth to this.Dont use a JDM ecu.They run like crap because they have no PA sensor in the ecu.Jdm ecus calculate fuel at sea level.So if you go up and down in elevation your tune will be off.Stick with USDM ecus youll be happy.
Black R
Mar 22, 2005 07:27 AM
Jmunk
Feb 23, 2005 04:54 AM
kerby116
Nov 5, 2004 12:14 PM
raene
Apr 28, 2003 05:46 PM
hYpE-R-29
Apr 6, 2003 04:32 PM
