injectors?
Old Aug 3, 2003 | 08:17 PM
RudeLude's Avatar
Default injectors?
what size and what kind of injectors should i get for a 500hp H22a? also, what kind of fuel pump should i use?
thanks
daniel
Old Aug 4, 2003 | 03:34 AM
The sweed's Avatar
Default Re: injectors? (RudeLude)
72lbs should work out for you... summit hasém for around 80 dollars..
Old Aug 4, 2003 | 08:37 AM
RudeLude's Avatar
thanks sweed, any comments on teh fuel pump?
daniel
Old Aug 4, 2003 | 10:16 PM
RudeLude's Avatar
Default Re: (RudeLude)
would the dsm 450's be able to feed 15psi on a built h22a? if not, what about the rx7, are they 550's? if they can, where can i get a set? would they be albe to support me and will they be able to fit?
thanks
daniel
Old Aug 4, 2003 | 10:20 PM
11psiTurboSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude &raquo;</TD></TR><TR><TD CLASS="quote">would the dsm 450's be able to feed 15psi on a built h22a? if not, what about the rx7, are they 550's? if they can, where can i get a set? would they be albe to support me and will they be able to fit?
thanks
daniel</TD></TR></TABLE>
i doubt it... go with 860cc+ if your shooting for 500hp off a thristy H22
Old Aug 4, 2003 | 10:28 PM
RudeLude's Avatar
i'm talkin about just 15psi.
Old Aug 4, 2003 | 10:30 PM
LJR-LUDE01's Avatar
the 450 won't do for 15 PSI, you need go bigger. here you can use this to get a close idea at how big of injectors you need.
http://www.rceng.com/technical.htm#WORKSHEET
Old Aug 4, 2003 | 10:36 PM
porsche997dc2's Avatar
Injector sizes are determined by targeted horse power, not by engine size. I would choose something from 800cc-900cc. Go big injectors and run low fuel pressure.
pcguy760
Jul 1, 2008 09:18 AM
reditr
Jan 29, 2006 06:47 PM
mitsuman
Sep 2, 2002 03:38 AM
