Uberdata Question
Old Mar 20, 2005 | 03:54 PM
the.hamburglar's Avatar
Default Uberdata Question
when i burn a chip with uberdata after data logging for perfect tuning at 7psi, will i need to data log another WOT pull at 12psi and make a new chip different from the 7psi chip?
Old Mar 20, 2005 | 04:05 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Uberdata Question (hamburgler)
um... yes... duh
oh, and next time ( so you dont **** off the uber forum mods that frequent here)
post it here
http://www.ecimulti.org/uberdata
Old Mar 20, 2005 | 04:34 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamburgler &raquo;</TD></TR><TR><TD CLASS="quote">when i burn a chip with uberdata after data logging for perfect tuning at 7psi, will i need to data log another WOT pull at 12psi and make a new chip different from the 7psi chip?</TD></TR></TABLE>
Is your map tuned for 12 psi?
That should make a light bulb go off in your head...
wantboost's Avatar
Who is Mr Robot?
Default Re: Uberdata Question (93turbo16)
well, he could run 12psi on a 7psi tune. Just dont expect it to last for more than a few seconds. lol
Old Mar 20, 2005 | 04:51 PM
BlueShadow's Avatar
Assuming your motor can handle it, you can just tune your car for 12 PSI. Your fuel and timing from 0-7 PSI shouldn't change when you set your boost controller for 7 PSI. Tune for 12 PSI...turn down our boost controller from 12 PSI down to 7 PSI, make a pull to make sure you AFR's are still good. If they are, then burn your chip, and just use your boost controller to switch back and forth between 12 and 7 PSI.
ericschimmel
Jun 18, 2007 06:47 AM
memorybox
Mar 5, 2007 04:22 PM
WolfGod
Jul 28, 2006 12:26 PM
JrCRXHF
Jul 12, 2005 09:16 PM
*Boostwerks*
Jan 13, 2004 10:39 AM
