UBERDATA: Fix hunting idle on cold engine
Old Nov 3, 2003 | 07:52 AM
baphomet's Avatar
Default UBERDATA: Fix hunting idle on cold engine
My idle bumps up and down until the car has been driven a bit, I am new to tuning so I ask for some advice.
I am using usdm p30 maps in jdm p72 code on a edm p28. I have a b16a2.
Old Nov 3, 2003 | 08:00 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: UBERDATA: Fix hunting idle on cold engine (slashDEVslashNULL)
It may not be your uberdata. It may be your fast idle control. That's what mine was. You can fix it.
Old Nov 3, 2003 | 08:10 AM
baphomet's Avatar
Default Re: UBERDATA: Fix hunting idle on cold engine (HybridcivicLS-T)
runs fine on stock ecu
Old Nov 3, 2003 | 08:17 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">runs fine on stock ecu</TD></TR></TABLE>
Yeah mine did too sometimes I dunno just trying to help. that what was my problem though. I had the same problem, It would go up and down dramaticlly, my neighbors hated me.
Old Nov 3, 2003 | 08:19 AM
baphomet's Avatar
thanks for your help how did you fix it? Would it stabilize when the engine warmed up?
I just figured it was the new maps I was using since it never happened before on the obd2 ecu.
Modified by slashDEVslashNULL at 10:10 AM 11/3/2003
Old Nov 3, 2003 | 08:22 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">thanks for your help how did you fix it? Would it stabilize when the engine warmed up?
I just figured it was the new maps I was using since it never happened before on the obd2 ecu.</TD></TR></TABLE>
Yep it would stop when the engine warmed up and it didn't do it on my obd2 ecu niether. I thought it was becuase of the ecu's. The obd2 can correct things unlike the obd1's
Old Nov 3, 2003 | 09:12 AM
baphomet's Avatar
I am going to try this here is the link in case anyone else has this problem.
https://honda-tech.com/zerothread?id=653851
Thanks a lot!
Old Nov 4, 2003 | 08:06 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
No prob
Old Nov 4, 2003 | 08:42 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">
Yep it would stop when the engine warmed up and it didn't do it on my obd2 ecu niether. I thought it was becuase of the ecu's. The obd2 can correct things unlike the obd1's</TD></TR></TABLE>
Incorrect, the OBD2 IACV runs on a different frequency than the OBD1 shizzle.
I've been through this a couple different times, the idle properties get worse the bigger the injectors - the problem is twofold; you need to fiddle IACV in Uberdata until it idles decently (but will most likely still be muddy and fluctuate a little) then start tuning the part throttle maps. Idle can be affected by most of the readings between 0-1500 rpm and 26 in/hg to 15 in/hg.
You've been tuning just the last two or three vacuum columns, huh?
Old Nov 4, 2003 | 08:59 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: UBERDATA: Fix hunting idle on cold engine (J. Davis)
that's fine, just sounds like the problem i had and that was my fix.
Old Nov 4, 2003 | 10:02 AM
baphomet's Avatar
I have stock injectors. I put the stock obd2 ecu in and I got code 10 iat sensor. Would this cause it? I don't get a code with the obd1 ecu unless I run the stock jdm p72 bin w/knock disabled, then it starts, revs drop, cel comes on, and idles at ~3k, almost like its not reading the rom. EDIT: Or its in limp mode. It worked before though. I will swap the iat sensor and see what happens and also try the iacv in uberdata. I have not played with the maps yet.
Another weird thing I noticed, when I had the bin I made with p30 values in the jdm p72 bin, if I held the rpm at any point, say 3k, it would drop then rise over and over. EDIT: But it doesn't throw a code. weird because I put the values in the jdm bin. I wonder if that bin is okay, I am worried because I used crome to copy and paste the maps and adjust the scalars, and crome is really buggy. BTW it isn't ftl.
Modified by slashDEVslashNULL at 8:30 PM 11/6/2003
Old Nov 6, 2003 | 07:55 PM
PHiZ's Avatar
Chipped ECUs are going to throttle hunt, learn to live with it
-PHiZ
Old Nov 6, 2003 | 08:00 PM
falcongsr's Avatar
What is this crap?
Default Re: UBERDATA: Fix hunting idle on cold engine (PHiZ)
h0ndata too?
Old Nov 6, 2003 | 08:12 PM
Default Re: UBERDATA: Fix hunting idle on cold engine (falconGSR)
Where do you think I got the tip that I needed to tune higher up the pressure scale to tune my idle? Hyundaidata!
It almost makes up for the notable number of errors regarding their product. RPM and MAP scalars, claims that the Honda MAP sensor reads higher than it does, etc.
Old Nov 6, 2003 | 08:13 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Chipped ECUs are going to throttle hunt, learn to live with it
-PHiZ
um
hondata too?
Old Nov 6, 2003 | 08:38 PM
PHiZ's Avatar
Dunno, I sold mine
J.Davis definitly seems to have an opinion on it, and his word is gold to me.
I personally don't care enought to investigate. YES, it would be nice ot have tools to minimize it. And blake has given us those tools (thanks blake). But to me, it's the cost of doing business.
It's an extra incentive to let the car warm up, like you should be doing anyways
Oh yeah, and someone smarter than me said that fuel up to like the 3rd or 4th column can affect your idle... And I noticed that there is a nice square in the upper left hand corner, where all the ignition values are the same.... up to ~1krpm??? I think the advice was to not pull too much fuel.
-PHiZ
Old Nov 6, 2003 | 08:46 PM
falcongsr's Avatar
What is this crap?
oh.. um. well i didnt know JD was answering my Q. didnt make any sense. i been huffing solder flux fumes for a couple hours.
Old Nov 6, 2003 | 10:54 PM
Yes, even though you have not been forthcoming with the max-sex, I answered your question.
:&gt;
Old Nov 7, 2003 | 03:23 AM
toxicshit's Avatar
Default answer to question from topic id 626171
this is my winhex report of the bin that i send to slashdevvslashnull. that bin worked good for him
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by report.txt &raquo;</TD></TR><TR><TD CLASS="quote">
Search for differences
1. F:\Programs\CROME\Int269stocknoknock.bin: 32.768 bytes
2. F:\Programs\CROME\Int269stock.bin: 32.768 bytes
Offsets: hexadec.
5467:00FF
1 difference(s) found.
@phiz & @slashdevnull: PA is already disabled on the jdm integra 269 rom that ive send to slashdev null !! and ive cecked it again
this is what it looks like :
1. F:\Programs\CROME\slashdevnullalloff.bin: 32.768 bytes
2. F:\Programs\CROME\slashdevnullallon.bin: 32.768 bytes
Offsets: hexadec.
5467: 00 FF
5469: 00 FF
5471: FF 00
3 difference(s) found.
Greetz Erwin..
p.s. sccs with it
Old Nov 7, 2003 | 07:03 AM
InTeGrA B18b1's Avatar
Default Re: answer to question from topic id 626171 (toxicshit)
i didnt read all that stuff but my cousin says that it does that to lubricate the turbo or warm it up or something.
Old Nov 7, 2003 | 07:11 AM
falcongsr's Avatar
What is this crap?
Default Re: answer to question from topic id 626171 (InTeGrA B18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">i didnt read all that stuff but my cousin says that it does that to lubricate the turbo or warm it up or something.</TD></TR></TABLE>
wow.
Old Nov 7, 2003 | 07:51 AM
nevin's Avatar
Default Re: answer to question from topic id 626171 (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">
wow. </TD></TR></TABLE>
haha word
mikeunreal2
31
Mar 12, 2006 10:28 PM
J_Trez
Apr 29, 2005 04:46 PM
snouka
11
Mar 25, 2005 06:01 AM
LostSolVTEC
Jul 22, 2004 04:31 PM
saucyhatch
10
Nov 13, 2003 08:25 PM
