uberdata/ ecu chipping?????
Old Mar 19, 2004 | 05:21 PM
  #26
5STAR3's Avatar
Default Re: uberdata/ ecu chipping????? (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't consider them optional. They are called decoupling capacitors, and they filter the power supply to the gate and EPROM chips. They are also .01uf not the .1uf as stated before.</TD></TR></TABLE>
as for them being .01uf and not .1uf, i copy and pasted my info from the uberdata help links.....
so you can take it up with them
Old Mar 19, 2004 | 05:35 PM
  #27
Jim Truett's Avatar
Default Re: uberdata/ ecu chipping????? (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">
so you can take it up with them </TD></TR></TABLE>
They are wrong. The printed value is 103, which any good electronics tech would recognize as .01uf.
http://leonardo.eeug.caltech.e....html
A .1uf might work fine in a USDM ECU, but capacitors that are too large can cause instability in JDM ECUs.
Old Mar 19, 2004 | 08:03 PM
  #28
smallttocs's Avatar
Default Re: (envision2teg)
haha, ive only had one class that dealt with electronics, im retarded </TD></TR></TABLE>
its all good man - it made me laugh
Old Mar 20, 2004 | 05:52 AM
  #29
cccya's Avatar
Default Re: (smallttocs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smallttocs &raquo;</TD></TR><TR><TD CLASS="quote">
its all good man - it made me laugh </TD></TR></TABLE>
funny yes....
Old Mar 20, 2004 | 06:52 AM
  #30
Scott - 93HB Si's Avatar
I've used 0.1uF caps on both USDM and JDM ECU's without any issues.
Old Mar 20, 2004 | 07:37 AM
  #31
T-RO's Avatar
Default Re: uberdata/ ecu chipping????? (DC2R714)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">Viren can you use a regular soldering Iron to socket ECU's or do you need some special Soldering station or something?</TD></TR></TABLE>
I use Radio Shack soldering irons for my chipping.
I use a 15watt to solder with and a 40watt w/ desoldering braid to desolder holes.
Old Mar 21, 2004 | 10:25 AM
  #32
The Destroyer's Avatar
Default Re: (MadCow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCow &raquo;</TD></TR><TR><TD CLASS="quote">
How could it be any more simple? Such is the nature of the beast, you can only simplify things so much before they are what they are.
If you're not a DIY sort of person, willing to do research and make mistakes here and there... uberdata isn't for you. Just as in learning anything, there are always mistakes to be made.</TD></TR></TABLE>
I know, I am a DIY type of person. Just looking at the ecu confuses me, but if people say its easy ill start reading. Thanks for letting me kows its not as hard as i thought.
Edit: If anyone has aim/aol could you im me so I can talk about it? tia.
Modified by I Need Money. at 12:21 PM 3/21/2004
Old Mar 21, 2004 | 11:56 AM
  #33
Mad Cow's Avatar
Default Re: (I Need Money.)
No problem. Just hop on the uberdata board and do some reading. There's a faq on the site too, and a help file somewhere.
http://www.ecimulti.org/uberdata
It's really not as hard as people make it out to be.
Old Mar 21, 2004 | 12:33 PM
  #34
ScottEK's Avatar
Takes a little bit of reading but you can do it, I didn't know anything about überdata last month but in the past month I've figured out so much. I've built two conversion harnesses for OBD-0 to OBD-1 and now I'm doing a 2b to 1. By summer überdata is going to be on all the turbo cars in my town. I'm loving it. Check out the Willems burner if you're on a budget you can pick them up around $50.
Old Aug 5, 2004 | 06:04 AM
  #35
GPNY's Avatar
Default Re: (beta13)
up from the archives, I need to keep this in my watched list...
Vtec140
Oct 3, 2017 02:15 AM
feriotypeR
Apr 6, 2010 12:37 PM
es_squared
Oct 6, 2004 08:51 AM
vtecpower2000
Nov 11, 2003 10:25 AM
