uberchip question....im running lean on a small turbo !!!
Old Oct 9, 2003 | 03:12 PM
delslow94's Avatar
Default uberchip question....im running lean on a small turbo !!!
heres my problem...once i reach 3lbs of boost the thing bogs out. as im spooling it goes very lean. now im setup for dsm 450s which im running with everything wired up correctly. i have 40psi on the fpr. what do u suggest i bump it up to in order to acheive anything decent. oh and its a saab t3 on a b16 w/gsr cams, 2.5 cat and exhaust. im thinking around 50psi maybe? im hoping to get a new chip burned soon but until then what should i do...and i know dont boost it but since its small it starts spooling at 3k. thanks
Old Oct 9, 2003 | 03:14 PM
Mr. Softee's Avatar
Default Re: uberchip question....im running lean on a small turbo !!! (delslow94)
dyno tune it.
Old Oct 9, 2003 | 03:21 PM
delslow94's Avatar
Default Re: uberchip question....im running lean on a small turbo !!! (94goldjungsr)
im definately going to...i just want to stop the hessitation till my dyno time next week
Old Oct 9, 2003 | 03:25 PM
Mr. Softee's Avatar
you shouldnt be boosting on an untuned map.
Old Oct 9, 2003 | 05:02 PM
delslow94's Avatar
oh i know this...but when i drive its either half throttle to 3k or like no throttle at all which takes forever to get moving. plus to get to the tuner it is a 3 hour drive at 4k...any little throttle makes it start to spool. anyone else have suggestions
Old Oct 9, 2003 | 05:10 PM
Mr. Softee's Avatar
take out wastegate spring
sam
Old Oct 9, 2003 | 08:50 PM
InTeGrA B18b1's Avatar
your turbo is spooling to fast and therefore you run lean througout the powerband. same thing happen to my cousin
neoc03
Dec 6, 2007 12:41 PM
psychotic_z
Nov 21, 2003 10:40 PM
VTgringo
Aug 17, 2003 07:21 PM
justinCO
Oct 29, 2002 04:22 PM
