UberChip: Non-Blinking CEL
Old Aug 11, 2003 | 08:21 AM
94TurboGSR's Avatar
Default UberChip: Non-Blinking CEL
I put my DSM 450s and my Uberchip in lastnight. After about 5 seconds of the car running the CEL came on, and it wouldn't blink. I'm sure I put the chip in the right way (I know someone that made that mistake previously). Anyone have any experience/ideas/suggestions?
EDIT: It's in limp mode, and it's idling ALMOST normally with the 450s... if that says anything
Old Aug 11, 2003 | 12:14 PM
94TurboGSR's Avatar
Default Re: UberChip: Non-Blinking CEL (TealTurbo)
Maybe a picture will help?
Old Aug 11, 2003 | 12:36 PM
psileepR's Avatar
New User
did u short the blue connector by the ecu on the passenger floor side of the car?
Old Aug 11, 2003 | 12:45 PM
Mr. Softee's Avatar
Default Re: UberChip: Non-Blinking CEL (psileepR)
that means you fucked up on the chipping or you didnt burn the chip right.
Old Aug 11, 2003 | 12:53 PM
NateTEG95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psileepR &raquo;</TD></TR><TR><TD CLASS="quote">did u short the blue connector by the ecu on the passenger floor side of the car?
Yes.
Old Aug 11, 2003 | 12:55 PM
NateTEG95's Avatar
Default Re: UberChip: Non-Blinking CEL (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">that means you fucked up on the chipping or you didnt burn the chip right.</TD></TR></TABLE>
Well, the ECU was already socketed.. it's been socketed for a few years, I just swapped the chips. Maybe the chip didnt burn right.
What happens if I put an LS uberchip in a P72? I have a known good LS chip...
Old Aug 11, 2003 | 01:13 PM
Mr. Softee's Avatar
Default Re: UberChip: Non-Blinking CEL (NateTEG95)
did you put the chp in the right way
Old Aug 11, 2003 | 01:17 PM
tegasaurus's Avatar
i experienced this only it went away after i reburned the chip. might want to try reburning it just in case.
Old Aug 11, 2003 | 01:19 PM
R6Elmo's Avatar
he said he made sure he put it in the correct way. I think putting it in the wrong way would just make the motr not even run!
Did you check to see what the CEL light code was even?
And as far as i know, the LS chip should be in the p74 or the p75. the p72 is a GSR ecu correct? maybe teh chip is looking for vtec or something.
Danny
Old Aug 11, 2003 | 02:01 PM
95TurboLS's Avatar
Default Re: UberChip: Non-Blinking CEL (R6Elmo)
The chip was put in the right way because i did it. I put my first one in backwards and it fried the chip but still ran in limp mode as his is doing now. We did not burn the chip wrong because we took it to john at secret services so he could do it. Everything was installed correctly, maybe the chip just didnt burn correctly? Is that possible?
Old Aug 11, 2003 | 02:03 PM
95TurboLS's Avatar
Default Re: UberChip: Non-Blinking CEL (95TurboLS)
tegasaurus, are you talking about rebeurning the same chip , or a new one?
Old Aug 11, 2003 | 02:20 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TurboLS &raquo;</TD></TR><TR><TD CLASS="quote">tegasaurus, are you talking about rebeurning the same chip , or a new one?</TD></TR></TABLE>
you should have a reburnable chip
Old Aug 11, 2003 | 02:41 PM
95TurboLS's Avatar
Default Re: UberChip: Non-Blinking CEL (TeStUdO)
how do you know if its reburnable?
Old Aug 11, 2003 | 03:22 PM
tegasaurus's Avatar
all eeproms are re-burnable.
It just a happened one time. I had 1 map on the car, ran good... changed maps a little bit leaner, it was good but not good enough, went to change it again then it did the non checkable code. So we went back and reburned a different map and then the code went away.
-ryan
Old Aug 11, 2003 | 03:30 PM
NateTEG95's Avatar
Default Re: UberChip: Non-Blinking CEL (tegasaurus)
What do you have to do to reburn it? Just pop it in and write the bin again?
Old Aug 12, 2003 | 04:05 PM
94TurboGSR's Avatar
Still no dice. Got the damn thing reburned and it still throws the CEL. Could it be the wiring on my 450s? Maybe one of the Radio Shack resistors is bad?
turbocutlass
Jul 26, 2007 08:03 PM
ham
Apr 29, 2007 07:27 PM
RexB16
Jun 3, 2005 10:34 AM
Vtec92Civic
Mar 30, 2005 11:54 AM
Scean
11
Mar 3, 2004 10:43 AM
