TYPE R TURBO
Old Jul 20, 2005 | 12:19 AM
ekim952522000's Avatar
Default TYPE R TURBO
Ok guys im turboing my type r ive got a hks manifold, a garrett gt25 ball bearing turbo and a sperco liquid intercooler im looking for 250whp. as of now my motor is stock, what would it take to get that kinda power and keep it reliable? what do i need to get done? this car is for autocross that's why im using such a small turbo and only looking for 250whp. also my daily driver.
Old Jul 20, 2005 | 12:34 AM
NumberB's Avatar
Default Re: TYPE R TURBO (ekim952522000)
ems and and a good tune/tuner
Old Jul 20, 2005 | 03:20 AM
freakie's Avatar
Default Re: TYPE R TURBO (milb16a)
get urself an autronic pnp board from either: tony1 or darkturbo (some know him as arturbo) or ben strader (efi101).
u cant go wrong.
Old Jul 20, 2005 | 04:12 AM
boostjunkie757's Avatar
get a thick headgasket....
and make as much power or more than i am.
Old Jul 20, 2005 | 06:27 AM
swlabhot's Avatar
Default Re: (boostjunkie757)
Getting a thicker HG will lower your compression. I don't see any relation how this can make more power ?! If anything, its quite the opposite!
Old Jul 20, 2005 | 06:32 AM
beerbongskickass's Avatar
Default Re: (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Getting a thicker HG will lower your compression. I don't see any relation how this can make more power ?! If anything, its quite the opposite!</TD></TR></TABLE>
The reason it would be a good idea to lower the compression is because it will be much safer to run more boost and easier to tune. I am guessing this is a daily driver on pump gas, so lower compression is your friend. You probably won't notice much low end difference anyways.
Old Jul 20, 2005 | 06:58 AM
turbosi03's Avatar
Default Re: (beerbongskickass)
since you already have a good HG on there why don't you blow that one first...
Old Jul 20, 2005 | 08:05 AM
TheShodan's Avatar
Moderator
Default Re: (turbosi03)
I'd concentrate on the tuning and managemen aspect and keep the compression for your AutoX experience. The on/off boost response would be a bit easier to navigate w/ the normal compression of the Type R. Just don't skimp on the tuning aspect, please.
Old Jul 20, 2005 | 11:05 AM
Default Re: (TheShodan)
i was thinking of getting hondata how well would this work for my setup? do any of you guys use hondata?
Old Jul 20, 2005 | 12:24 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: (ekim952522000)
what's hondata?
Old Jul 20, 2005 | 02:26 PM
Default Re: (2000psi)
this http://www.hondata.com/s300.html
so are you guys saying i can get 250whp with stock internals?
Old Jul 24, 2005 | 04:51 PM
no one know if need to build my engine to get this much power
Old Jul 24, 2005 | 05:17 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">I'd concentrate on the tuning and managemen aspect and keep the compression for your AutoX experience. The on/off boost response would be a bit easier to navigate w/ the normal compression of the Type R. Just don't skimp on the tuning aspect, please.</TD></TR></TABLE>
Good advice. Follow it
boostedcivicsir's Avatar
Mr. Badwrench
i made 230 whp with a 9:1 1.6L at 7 psi. 250 should be no problem.
Old Jul 24, 2005 | 06:44 PM
jdmvtec28's Avatar
It should not be a problem producing that kind of power with what you have, but your issue will be reliability. Like others before me replied, a good tune/tuner will be essential to reliable horsepower. If it were me and I were keeping the internals stock, I would opt for the thicker headgasket to drop the compression ratio a bit, just so you can A either run more boost, or B not have to worry about detonation as much. Good Luck
gustavito1986
Dec 6, 2007 10:10 AM
187Chor
Nov 30, 2007 08:47 PM
typeRintegra
Apr 22, 2007 01:47 PM
93MR2Turbo
Feb 24, 2004 02:28 AM
scarface
Sep 30, 2002 06:45 PM
