Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
#1052
Re: Txdragon's D16Z6 project: I've just boarded the Z6 bandwagon..
I know. I'd probably hate myself for the rest of my life if I did. Lol! I'm laid up right now and not supposed to do anything except get to the bathroom, for the next 2 weeks minimum.
Between downtime and pain meds, my brain is going in 90000000 directions. Lol!
I'm scheduled to dyno in August. I don't want to do anything with my car (trade, sell, loan, etc.) until after that.
#1053
Just don't do anything with the car at all LOL. Waste some money on parts to cope for now haha.
#1054
As for putting more into it, I'm almost at an end to what I can upgrade. About the only thing left I haven't messed with is a rear drum to rotor brake conversion.
#1055
E85 is pretty popular but, anyone running E98? Any reason I shouldn't? The tuner I have been speaking with that will be with me on the dyno in Aug says he wouldn't, but that was his personal preference. It raises a bit of a red flag if the tuner wouldn't use it but, it wasn't anything more than just personal preference. So.. Anyone have any experience there? The main reason I ask is that I will have to order E85 because there are no stations near me and they sell E98 as well and that happens to be much cheaper per 54 gal drum. I also figure that with potential inconsistencies with E85, E98 would be better anyways as if there would be an inconsistent batch, it's likely to be closer to the E85. lol! Let me know, folks!!
#1056
O.G. triple O.G.
I would stick with E85. I know stations like Sheetz do carry both but most others only have E85.
#1057
I think your main issue with E98 will be how harsh ethanol is on fuel components. I'm not sure how much of a difference there is between the 'lubrication properties' with ~15% of ethanol compared to 2% but that's worth considering. If you have ptfe an lines then that's a little less of a concern, but you still want to keep in mind if the pump, regulator, filter, injectors, and any rubber lines or o-rings in the system are ethanol-friendly.
If everything is ethanol-friendly, I'd probably send it with E98 if I was in your boat with no E85 stations close to me and E98 being a good bit cheaper by the drum.
#1059
#1060
I haven't looked to see how much stock rubber hose is actually left from the tank to the hardline but, that's bound to be my weakest link here.
I've priced the sensor and pigtail and they are surprisingly inexpensive! I'm looking into this and BBG components before tuning. Just need to run 475 dollars worth of fuel by the missus. Lol! I'll probably only order 20 gallons to tune with for now though.
My largest concern here is exceeding my intended stop point on power for the stock sleeves. The machinist said he saw no problem holding 425whp. 450 and over he said would be pushing the envelope.
That being said, this is a big spend to potentially start breaking ****.. I can still see 400 pretty easily on pump 93; my potential tuner says he believes I am already there. He's been absolutely awesome and looking over my street tune as I go along and helping me here and there at no extra charge. I'm more than excited to see what this gentleman will be able to do for me on the dyno. Anyhow.. BBG is definitely in the cards, corn fed is still up in the air..
#1062
I saw E98 and looked at 2 concerns.. that harshness of Ethanol, and the consistency of the blend.. If there's a difference in ethanol consistency in E85 that causes concern that it may be closer to E70 or something like that, I'd figure E98 could be closer to E85 on MOST cases. All my fuel components said they were E85 compatible; the AEM rail, Aeromotive regulator, Aus Injectors (I think these are even compatible with methanol), Walbro Hellcat, Russell fuel filter (unsure but it is a stainless mesh filter), and the fuel lines that came with the filter and fittings had E85 on the packaging.
#1063
Actually, I haven't. May look into that rather than the all out fuel conversion. Isn't that a fairly pricey endeavor as well?
40 micron filter
Agreed. There are plenty of people who run E85 through stock hard/rubber lines and normal an lines, just depends on what you're comfortable with. If you check the fuel pressure often and check/change out the fuel filter regularly I imagine you'd be fine with E98. What micron is the filter?
#1064
I honestly don't know how much to buy and install the kit. E85 isn't popular in my area so when I get a turbo set up I'm going to look into it.
#1065
I run E98, if you are looking for a good fuel that is consistent go with buying drums of E98 and call it a day. The problem with E85 at stations is the inconsistency of blends, stations very with consistency and since you don't have any stations close to you anyway I would just order drums of E98.
#1066
I'm hoping that running true flex fuel will help smooth out any inconsistencies with fuel. I'm lucky and have E85 at several stations in my area. I'm planning to dyno tune on 2 fuels - pump 93 gas (E10) and pump E85. I've got flex fuel running and after tuning, Hondata should be able to interpolate between a low boost map (which will be set up on the 93/E10) and a high boost map (which will be set up on E85) based on ethanol content of the fuel. You can set up the "slope" of this interpolation to be as aggressive as you'd like. The stock settings in Hondata are for up to E85, but you can easily change that to E98 if you wanted. This would allow you to run your barrels of E98 or add some 93 pump gas in the tank if you are ever caught out somewhere without more ethanol.
#1067
At any rate, I like the idea of being able to go with either.
#1068
Do you order your 98 from Sunoco or VP (or any other fuel place like that)? And do you test the mixture for consistency? And if you do, is it pretty much always in that range between 85 and 98?
I had looked into it before and yes, Neptune supports flex fuel. There are actually many folks that say it is a bit better on Neptune than Hondata; for those that use or have used both programs. How it is better, I'm not sure. Haven't gotten that far into it. Maybe easier, maybe more accurate, **shrug**
#1069
Lol, this is what stopped me from buying drums when I started to worry about the inconsistencies at the pump. All the more reason to tune it for flex fuel now, then hopefully later on you will get E85 available nearby and will already be set up for it. It's still under $2/gallon here.
#1070
Moderator
#1071
Now fill us in on making this methanol, good sir! Would that also make good for the meth/water injection to use with pump 93?
#1072
I might buy into some of that good fuel sometime, I’ve put just over 400 miles on this motor since the rebuild ( took three months) and other than track time it won’t see the street much anymore, so It would not be wasted. But almost 500 bucks is a hard pill to swallow, but it would last a long time.
#1073
Moderator
I'll get into that formula later. I'm making sure my thoughts aren't on deaf ears with the PCV Catch can thread, first.
I don't give away the good stuff just to do so.. there has to be a good audience that will want to give a ****, first. I've learned that as this forum has changed over the years. So that people aren't wasting their time, writing OR reading.
#1074
#1075
I dont want to pay that much though. I thought it would be my ONLY option. I found a closer (not by much) source for E85. Current price is 1.94/gal. So I could load a barrel in my truck and fill that once a month no prob. But.. It's pump E85 so then I'd have to worry about those inconsistencies. I may just look into water/meth spray to add with my pump 93. That should help out. I've just heard lots of AEM kits failing though, most recently that i know offhand was in Calidad's build. **shudder**
