Twincharging
Old Mar 11, 2021 | 05:46 PM
Kai Bautista's Avatar
Default Twincharging
Hi my honda now currently has a supercharger on it sc14 from toyota to be exact, now.. i bought a new engine and will fully build it i want to add turbo so question is.... Does anyone here build a similar setup? How would the piping be? SC to turbo or turbo to sc? I want to keep the SC btw 😊
Old Mar 12, 2021 | 07:29 AM
Full_Tilt's Avatar
Default Re: Twincharging
Its been done a few times. You kinda get the best and worst of both worlds. The supercharger gets you improved scavenging, and instant boost off idle, but with the parasitic loss, high rotating inertia, and poor thermal efficiency. Then you still have the heat and packaging complexity of a turbo setup, but youre missing out on the top end power and good efficiency you get with a FMIC because youre cramming the boost through the supercharger. You can make up for that last bit by using a bypass, but even still.
IMO, a properly sized turbo setup accomplishes the same thing, only its better and lighter.
Superchargers are used because people want to be different, not because they are the optimal solution. It sounds like you have already made up your mind about keeping it on there, so you have your answer right there. A twin charged setup will be "different" and that is apparently your goal. So have fun.
To answer your question though, you would want to run the turbo compressor to the supercharger, because the turbo will most likely way outflow the supercharger, unless you use some kind of super tiny turbo. Doing it the other way would make for a really poor performing setup.
Old Mar 21, 2021 | 03:03 AM
Thanks for this info yes i want to try a different setup twincharging isnt common reason for that is it will still be my track car so i want more top end power now, thanks for the advice again that actually make sense since turbo flows a lot more on the high rpm range 😊
Old Mar 27, 2021 | 06:07 PM
para pat's Avatar
Hey Kai
I've built twin charged and compound charged engines. With a paddle-based positive displacement supercharger like the SC14, you want turbo on top of blower. There is some merits to having the SC feed the turbo on a centrifugal setup. However, since you don't have a centrifugal charger I won't get in to it. It's also slightly different for a lysholm twin-screw style blower.
Really the only thing you need to look at is turbo sizing for the HP you want to make. You need to size the turbo like you would for a larger engine. How large? Take your current engine displacement multiplied by your current pressure ratio. If you have a 1.8L engine and are running 8 psi, that would be 1.8*[(14.7+8)/14.7], or equivalent to a 2.8L engine. Your turbo control strategy is going to be identical to a normal turbo set-up.
DeSerees
Jan 17, 2018 01:28 PM
thegoose2377
Jan 22, 2015 10:46 AM
GARRETTI
Jul 21, 2008 01:29 PM
1000kg88hb
Mar 12, 2007 01:01 PM
Kamin
Sep 6, 2001 08:18 AM
