Greddy Blue Box with Vafc II. Vtec Problems.
Old 05-15-2004, 06:34 PM
GForceInteg's Avatar
Default Greddy Blue Box with Vafc II. Vtec Problems.
Ok Narrow throttle and everything works great. But when it engages Vtec it immediatly hesitates. a/f gauge doesnt move, still showing 2 bars rich (Autometer a/f) no matter which way i take the fuel either +50 or -50 nothing changes? Seems to have plenty of fuel, Which i have the 310cc in and i have rc 550's in case and holly 255 pump. Any help on why i cant get it to burn thru vtec? I also have the msd 6btm and if I retard the ignition at all it chokes up???? my diagnostic shows 31 advanced timing? and again if i retard it only breaks up? Any help?
Old 05-15-2004, 06:50 PM
Default Re: Greddy Blue Box with Vafc II. Vtec Problems. (GForceInteg)
Plz i know alot of HT users think this is a stupid setup, but its what i have and would like some support if anyone has any information.
Old 05-16-2004, 08:46 AM
Bump
Old 05-16-2004, 09:15 AM
NotPhilTran's Avatar
its called hondata. uberdata. AEM
ANYTHING BUT THE HACK.!!!!!!
not trying to be a jerk, but uberdata is cheap and effective.
Old 05-16-2004, 10:19 AM
Cruiser G's Avatar
take off the vafc, it wont work well with the blue box. I'm pretty sure thats your problem.
Old 05-16-2004, 09:23 PM
Default Re: Greddy Blue Box with Vafc II. Vtec Problems. (stolencrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stolencrx &raquo;</TD></TR><TR><TD CLASS="quote">its called hondata. uberdata. AEM
not trying to be a jerk, but uberdata is cheap and effective. </TD></TR></TABLE>
I know your probably not trying to be a jerk but thats what my previous post was to do was eliminate these wasted responces.
I dont considerate a Hack, The hack is used Without the Blue Box. The bluebox gets me past the map sensor and some other obsticles im told, so i only need the vafc II to help out the blue box which is programed rich at 6psi. obvioulsy im lokoing to boost closer to 12-14. But im having trouvle as stated with my vtec, and im not to sure on why.
I have Crower stage 2 cams springs and retainers w/ Stock valves. and again the a/f isnt showing lean so i dont want to install the 550's quit yet.
Anyone??????? PLEASE?????
Old 05-16-2004, 09:38 PM
Quad-Damag's Avatar
run A blue box or a vfac u can't run both
runs like ****
run the hack and take the blue box out
or run the blue box and tune via fpr, becuase it runs mad rich yo
Old 05-17-2004, 06:54 AM
Default Re: Greddy Blue Box with Vafc II. Vtec Problems. (Quad-Damge)
Why cant i run both? looking for more detailed help here. Im no tuner I just have to run this car till the wifes rsx is done.
Old 05-17-2004, 07:50 AM
FuriousGeorge's Avatar
The blue box is designed to do 2 things: hide boost from your ECU and dump a ton of fuel under boost.
While the AFC can be used to do a number of things, the HACK is designed to: Hide boost from your ECU and CONTROL fuel, not add it. Typically it is used to lean out bigger-than-stock injectors (like 440s, etc).
Problem 1: you have two systems trying to hide boost from the ECU. Which one do you have spliced into your MAP sensor wire? Your problem of the AFC not doing anything no matter the setting could be because you dont have it hooked up to the MAP. If you have both hooked up I would think that is a bad idea.
Problem 2: You have a system on there that you should be using to lean out bigger injectors along with a system that is designed to make your injectors dump as much fuel as they can when you hit boost. I think this is self explanatory
Here is my suggestion. Take off the blue box. You stated that you already have bigger injectors (although I was a little confused as to what size and if they were in the car yet), so just hook up the AFC correctly and use them to lean out your injectors. Also, if you used the AFC to change your VTEC point, change it back to stock to see if it helps.
Old 05-17-2004, 07:58 AM
Default Re: Greddy Blue Box with Vafc II. Vtec Problems. (FuriousGeorge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuriousGeorge &raquo;</TD></TR><TR><TD CLASS="quote">The blue box is designed to do 2 things: hide boost from your ECU and dump a ton of fuel under boost.
Here is my suggestion. Take off the blue box. You stated that you already have bigger injectors (although I was a little confused as to what size and if they were in the car yet), so just hook up the AFC correctly and use them to lean out your injectors. Also, if you used the AFC to change your VTEC point, change it back to stock to see if it helps. </TD></TR></TABLE>
Ok, I am running 310s currently till i understand more of whats going on here I do have (RC 550's NOT INSTALLED). I have a few questions regarding all of this. I read that enourmouse post about the vafc stuff but that doesnt help me much with the blue box. This is my thinking. (Again im no tuner just trying to get by with what i have).
So instead of using the HACK, why not use the blue box to hide the boost which is hooked into map wire with vafc hooked up as instructions say, And now i should be able to use the vafc for what it is, A fuel control unit. But with your statement im thinking shouldnt i hook up the blue box to hide boost from the vafc which will in turn hide boost from the ecu?
Old 05-17-2004, 08:06 AM
Quad-Damag's Avatar
the blue box can't control bigger injectors, if u run the afc hack u have to run bigger injectors and it will run ok
That won't work, becuase the bluebox and the vfac don't like to work togather it's been done, and it just doesn't work, so u have to pick 1
BLUE BOX (STOCK Injectors)
VFAC (HACK) Search for more info on that
I am not a huge fan of the hack, i would of gone with a hondata or urberdata or ran like 7 to 8 psi on all stock motor with the blue box and tuned via fpr, so the fuel isn't so much
Old 05-17-2004, 08:35 AM
For Sale: 1998 integra gsr Basically everything done just needs tuned. LOL
Man this is to much, im a noob ill admit it. Ok what should i sell and what should i buy
Old 05-17-2004, 08:57 AM
TurboB18C1's Avatar
Uberdata
Hondata $$
Vafc is just a piggyback and will only tune your fuel curve but wont do anything for you Ignition.. that is one of the reasons i switched to a standlone unit..
I was running the greddy kit with a vafc and a blue box , but the vafc was not doing anything when i started to lean it out at top end... since the blue box was making the car run close to a 9:1 mixture... it did hisitate at part throttle..
I would sugguest you throw those 550's in and run a vafc hack to tune you fuel down at idle. But i would highly recomend Uberdata or Hondata..
Here is a link on some Hack info...
https://honda-tech.com/zero...age=1
Sorry about the spelling mistakes
Old 05-17-2004, 09:05 AM
PM-Performance's Avatar
Default Re: Greddy Blue Box with Vafc II. Vtec Problems. (TurboB18C1)
your other problem is your trying to read a/f output with a meter that isnt reading correct a/f so for all you know you could be pig lean .
Old 05-17-2004, 09:17 AM
99lspwr's Avatar
Default Re: Greddy Blue Box with Vafc II. Vtec Problems. (itr206)
You got waaaay to much **** goin on there man...Dump one or the other, but do not use both...It only creates problems like u are having.....BTW, your timing advance is waay to high...31 degrees!!!!Your gonna start to melt **** soon!!
Old 05-17-2004, 09:56 AM
Default Re: Greddy Blue Box with Vafc II. Vtec Problems. (99lspwr)
yeah the timeing i dont undertsnad i have the msd and when i retard it , it chops up like crazy under boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">your other problem is your trying to read a/f output with a meter that isnt reading correct a/f so for all you know you could be pig lean .</TD></TR></TABLE>
Im confused?
Old 05-17-2004, 09:57 AM
Could i hook a volt meter to the signal wire wouldnt this be the same as a the gauge only better?
Old 05-17-2004, 10:03 AM
your reading narrowband output , you need to be reading wideband . you need something to convert the signal. IE a wideband controller
Old 05-17-2004, 08:47 PM
Ok so should i buy a wideband? Im under the impression most dyno shops have them to install. I want to get one solid street strip map and leave it at that.
Old 05-18-2004, 06:24 PM
TurboB18C1's Avatar
If you are looking for a good street wideband at a good cost get a TECH_EDGE 2.0 wideband
go on this link
http://wbo2.com/default.htm
Old 05-18-2004, 08:11 PM
Thanks for the link, But I'm lost
gunmetalcivic
06-14-2004 10:53 PM
GForceInteg
05-04-2004 08:49 AM
mogz
12-12-2003 01:49 PM
yan
07-11-2002 06:22 PM
willyboyK20
02-25-2002 05:37 PM
Quick Reply: Greddy Blue Box with Vafc II. Vtec Problems.
