Twin disk info
Old Aug 20, 2007 | 03:01 AM
SwappedTURBOegg's Avatar
Default Twin disk info
I just bought a Competition Clutch twin disk for my koop. I was searching around for some info and read something about a pedal stop, i was under the impression i could just install it and go..also is there a break in period for a twin? ive never ran a twin before so any info would be greatly appreciated.
Old Aug 20, 2007 | 03:46 AM
DaveF's Avatar
Default Re: Twin disk info (SwappedTURBOegg)
no break in period.
about the pedal stop, on my car i welded a nut to the clutch "arm", down low by the pedal, and put a bolt with a nut. you simply adjust it so you push the clutch down far enough, and not overthrow the spring.
Old Aug 20, 2007 | 05:23 AM
alexsracing's Avatar
how much play do you need to take out of the pedal to the floor for he competition twindisk?
Old Aug 20, 2007 | 05:39 AM
twkdCD595's Avatar
Default Re: (alexsracing)
I am also curious... how would I know if I am overthrowing it without a stop?
Old Aug 20, 2007 | 05:46 AM
turbotypeR@SPEC's Avatar
25 Year Member
If it has mettallic discs, I woul just slip it pretty hard several times and it will be broken in pretty good. As far as the stop goes, you can adjust it to where it engages pretty close to the floor and you won't over extend the diaphram. The only problem with that is that your foot will have to travel farther to the floor to operate it, causing more time to push the clutch in. If you do a stop, you can raise the pedal adjustment up off of the floor to keep from having to push the clutch in so far.
Old Aug 20, 2007 | 07:20 AM
DaveF's Avatar
Default Re: (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">I am also curious... how would I know if I am overthrowing it without a stop?</TD></TR></TABLE>
if you push the clutch pedal down to a certain point, which allows clean gear change... but you would still have room to push the pedal down further. then you know you are over extending it, by pushing the pedal past that point.
Old Aug 20, 2007 | 07:23 AM
twkdCD595's Avatar
Default Re: (dturbocivic)
simple enough, kinda what I figured but I did not know for sure... thanks.
Old Aug 20, 2007 | 07:47 AM
sounds good, hopefully it the pedal will go pretty close to the floor like it did with my clutchmasters stage 5
grand champ
Sep 6, 2010 02:58 PM
justa4dr
Honda Civic (2006 - 2015)
May 27, 2009 11:07 PM
andrey320
Feb 25, 2008 04:21 PM
s4yama
Jun 9, 2007 06:41 PM
djmatix
Apr 26, 2007 07:05 PM
