turbotimer install ... need help bad!
Ok, here's the deal...I bought a turbo timer off ebay, and tried to install it. There are 5 wires, red, blue, yellow, brown and black....brown goes to parking brake sensor, black goes to ground...that, I'm positive.
Other three, I can not seem to get them right...I tried a million times, got ignition schemes from internet etc, but can get it to work. It lights up and I can adjust timing etc, but when I turn the ignition off the engine stops running ( I adjusted turbotimer to one minute). I would like to know, anyone driving a 4th gen civic (EF Civic) and done this, which wire from TT to connect to which one in igniton. Help, I'm desperate
Sure there is somebodey that has TT connected on his 4th gen civic!!!
Thank you!
Thank you!
2hotrod99> thank you, but I already know that...my problem is that I have 7 wires going out from ignition, and I can not figure out which one to connect to which...so I wanna know if somebody has already done it, just to write me here the pattern, which one to connect to which...
What years the car?
4th gens dont really have an ignition 1 and ignition 2 like newer cars..
Ignition for an ef is a Black/Yellow Wire
try connecting both ignition wires from the turbo timer to the black/yellow wire
you also may have to cut the black/yellow wire, connect one wire to one end of the cut, then the other wire to the other cut end, but try connect both into the black/yello wire
Modified by standbackimapro at 1:55 PM 5/29/2008
There are 5 wires from turbo timer... :
BLACK one goes to ground
BROWN one goes to parking brake
RED one goes to 12 V
YELLOW one goes to ignition key on
BLUE one goes to ACC
That's what it says in the installation instructions....
So, you're saying to connect BLUE and YELLOW both to black/yellow in the ignition harness?
Yah, put the Blue and yellow wire to the black/yellow wire if that dosnt work put the blue one to the Blue/white wire thats the accesory wire.. But try them both to the black/yellow first
AAARRRGGGHHHHH.....didn't work!
Tried both yellow and blue to black/yellow and tried blue to blue/white.....nothing worked
..when I turn the ignition key off the engine stopped every time...now you know why I am trying to get somebody that has a turbotimer on his 4th gen civic to anwser me!!!!....so if you know anybody with a turbotimer on 4th gen civic, please direct him to this topic!!!! I'm loosing my hope slowly
#Leo#
May 4, 2008 09:30 AM
crashtest Sonny
Dec 26, 2003 07:52 PM
