Turbonetics WG question
Old Apr 20, 2004 | 07:33 AM
fjt's Avatar
fjt
Default Turbonetics WG question
Why does my Deltagate/ MarkII has a different base? My WG looks bigger that the other regular deltagates i see.. Are they all 35mm?
Compare this Base
With MY WG base...
Its pretty heavy too.
Old Apr 20, 2004 | 07:35 AM
b18bturbo's Avatar
Default Re: Turbonetics WG question (fjt)
becuz you have a racegate and not the std 35mm deltagate
Old Apr 20, 2004 | 07:41 AM
fjt's Avatar
fjt
Default Re: Turbonetics WG question (b18bturbo)
Can u elaborate on this? Does it means that i cant run low boost, like what happens with Tial race gates?(no lower than 14.5PSI).
This wastegate came with all the Springs.
Is is better than the "regular" Deltagate then?
Old Apr 20, 2004 | 07:52 AM
DaX's Avatar
DaX
Loved
Community Favorite
What? I've got a TiAL wastegate and have a 0.4 bar spring in it [about 6 psi]. I don't know where you heard about TiAL's not being able to run less than 14.5 psi.
Old Apr 20, 2004 | 07:54 AM
b18bturbo's Avatar
that wg is racegate from Turbonetics. it also has many differeent spring combinations. It used usually on high hp setups. Its a great wg for the buck. It will not bolt up to a 35mm flange
Old Apr 20, 2004 | 09:49 AM
fjt's Avatar
fjt
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">What? I've got a TiAL wastegate and have a 0.4 bar spring in it [about 6 psi]. I don't know where you heard about TiAL's not being able to run less than 14.5 psi.</TD></TR></TABLE>
YOu can look at it here..
https://honda-tech.com/zerothread?id=773352
Look at posts #15, 16 and 17.
There is the Tial regular WG and the tial HP WG..
That one is for high boost application where it will not let you run anything less than 1bar..in othe words 14.5PSI..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">becuz you have a racegate and not the std 35mm deltagate </TD></TR></TABLE>
So is my Deltagate a 38mm? if not what it is and what flange do i need to put it on my manifold?
I am having a custom made Log Manifold.
Here are more pics of the WG.
Old Apr 20, 2004 | 09:53 AM
b18bturbo's Avatar
Default Re: (fjt)
You <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">
I am having a custom made Log Manifold.</TD></TR></TABLE>
On the first question you are looking at two different things. The WG is not a tial that you have it is a turbonetics made unit. Lets get that straight first. Alot of misinformation in this post.
You do not have a deltagate second off.
You have a racegate which is also made by turbonetics.
If you are having a custom made log manifold tell them to make it based on the racegate flange and you should be okay
Please read this http://www.turboneticsinc.com/wastegates.html
and understand what product you have first.
Old Apr 20, 2004 | 10:00 AM
fjt's Avatar
fjt
Default Re: (b18bturbo)
I know i dont have a tial but i meant that..Being a Racegate, if the function of it is Like a Tial WG for High HP which only lets you boost a minimum of 1 bar..
Sorry i didnt not put it in a clear way..
gonna read that link u post..Thanks man
Old Apr 20, 2004 | 10:02 AM
silverEH2's Avatar
Old Apr 20, 2004 | 10:15 AM
b18bturbo's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">I know i dont have a tial but i meant that..Being a Racegate, if the function of it is Like a Tial WG for High HP which only lets you boost a minimum of 1 bar..
gonna read that link u post..Thanks man </TD></TR></TABLE>
okay first off you have to check what spring you have on the WG I think if i rememebr correct the RaceGate can run a minimum 9 psi spring
Old Apr 20, 2004 | 10:22 AM
fjt's Avatar
fjt
WOW!! so i have a decent WG? (sorry im a newb with this).. The guy that sold it to me gave it for preatty cheap..I looked around and the price for the Racegate is almost twice as the Regular Deltagate...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">okay first off you have to check what spring you have on the WG I think if i rememebr correct the RaceGate can run a minimum 9 psi spring</TD></TR></TABLE>
Thanks..this is exactlly what i want to know. I bought it with all the springs.(look at the pic on above posts)
According to this online Catalog--&gt; http://64.225.76.178/catalog/wastegate.html
Springs are available in 3-5, 5-7, 7-9 and 9-13 PSI for both Gates (Regular and Racegates)..The springs are by color and i have all of them(they came with the WG when i bought it)
Old Apr 20, 2004 | 04:51 PM
DaX's Avatar
DaX
Loved
Community Favorite
Gotcha...I was confused, now I know you mean the HP gates.
Old Apr 21, 2004 | 05:14 AM
fjt's Avatar
fjt
Default Re: (DaX)
So This WG is a 42mm Right?
95GSRT
Mar 30, 2005 07:45 AM
adictionbass
Jan 6, 2005 05:10 PM
ebp 99 si
Jun 15, 2003 07:45 PM
TJ R
Feb 5, 2002 04:08 AM
