Turbonetics Turbo - I need some help identifiying this turbo!
Old 10-14-2007, 12:42 PM
AspectIndustries's Avatar
Default Turbonetics Turbo - I need some help identifiying this turbo!
Turbo was traded for parts - Long run short.
I know it was from a cybernation turbo kit. The company is long gone. I know they had offer the T3/T4 50trim Turbonetics and the upgraded 60-1 Turbo.
Which is it? !!!
I have it 57 t3t04e turbonetics. And the Compressor looks larger on this turbo!
But I do have some specs:
Its a Turbonetics T3 Flanged - Model T-16385 (tried turbonetics, they have no record of thier old model turbos)
Compressor Side has a 3inch inlet. 2inch outlet.
Inducerhas 6 fin & is about 2 1/8" and Exducer is about 3 1/4
Turbine Side has 4bolt T3 inlet, and 5bolt outlet.
This is the exact turbo pictured. That Vband Flange is a 3" inlet next to the turbo.
Any help would be appreciated!
Thanks.
Modified by AspectIndustries at 3:28 PM 10/14/2007
Old 10-14-2007, 02:19 PM
jDMJeRk's Avatar
The only way to really find out is to measure....
Old 10-14-2007, 02:24 PM
Default Re: (jDMJeRk)
What am I measuring?
Old 10-14-2007, 04:34 PM
twkdCD595's Avatar
Default Re: (AspectIndustries)
inducer/ exducer of the compressor and turbine wheels.
I asume there is identification plate on the center section of the turbo with the serial number and whatnot.
Old 10-14-2007, 04:45 PM
Default Re: (twkdCD595)
As listed above:
Inducer is about 2 1/8" and Exducer is about 3 1/4 diameter.
But...the Turbine wheel is 2.5"inch diameter.
Old 10-15-2007, 08:35 AM
Anyone want to enlighten me on how to recognize these measurements?
Old 10-15-2007, 01:36 PM
turbodano's Avatar
Looks like you have a Turbonetics T04E 50 trim compressor (not the same as the Garrett 50 trim) with the John deer 350 or 351 turbine wheel. That unit is good for 450+. Hope that helps you.
Not a bad turbo at all.
Old 10-15-2007, 04:03 PM
Jarfal's Avatar
Default Re: Turbonetics Turbo - I need some help identifiying this turbo! (AspectIndustries)
Turbonetics T3/T4.
soon i will try it on my H22
lakyoumo
05-26-2005 07:33 PM
whagkangmakulet
11-13-2001 05:21 AM
Quick Reply: Turbonetics Turbo - I need some help identifiying this turbo!
