Turbonetics Turbo - I need some help identifiying this turbo!
Turbo was traded for parts - Long run short.
I know it was from a cybernation turbo kit. The company is long gone. I know they had offer the T3/T4 50trim Turbonetics and the upgraded 60-1 Turbo.
Which is it? !!! I have it 57 t3t04e turbonetics. And the Compressor looks larger on this turbo!
But I do have some specs:
Its a Turbonetics T3 Flanged - Model T-16385 (tried turbonetics, they have no record of thier old model turbos)
Compressor Side has a 3inch inlet. 2inch outlet.
Inducerhas 6 fin & is about 2 1/8" and Exducer is about 3 1/4
Turbine Side has 4bolt T3 inlet, and 5bolt outlet.
This is the exact turbo pictured. That Vband Flange is a 3" inlet next to the turbo.
Any help would be appreciated!
Thanks.
Modified by AspectIndustries at 3:28 PM 10/14/2007
Thanks.
Re: (AspectIndustries)
inducer/ exducer of the compressor and turbine wheels.
I asume there is identification plate on the center section of the turbo with the serial number and whatnot.
Re: (twkdCD595)
As listed above:
Inducer is about 2 1/8" and Exducer is about 3 1/4 diameter.
But...the Turbine wheel is 2.5"inch diameter.
Looks like you have a Turbonetics T04E 50 trim compressor (not the same as the Garrett 50 trim) with the John deer 350 or 351 turbine wheel. That unit is good for 450+. Hope that helps you.
Not a bad turbo at all.
center, cybernation, id, identification, identifiying, kit, number, numbers, section, serial, size, t3, t3t4, t4, turbo, turbonetics
