Turbonetics Boost Controller
Old Nov 19, 2002 | 03:38 AM
7rrivera7's Avatar
Default Turbonetics Boost Controller
I was looking into electronic boost controllers when I came across the Turbonetics Variable Boost Control Regulator:
VARIABLE BOOST CONTROL REGULATOR
Change your boost level from the cockpit of your car with the TURBONETICS “ VBC “ kit. The “ VBC “ kit can adjust boost pressure on any Deltagate, Racegate or factory dual port actuator. Adjustable from stock to the indicated pressure above stock.
RANGE PART # PRICE
0 - 10 PSI 10402-10 $ 67.00
0 - 25 PSI 10402-25 67.00
0 - 50 PSI 10402-50 67.00
All kits come complete with fittings and “blue silicone” vacuum hose.
Is this as good as an EBC?
Old Nov 19, 2002 | 05:50 AM
tony1's Avatar
Default Re: Turbonetics Boost Controller (7rrivera7)
It's just a simple manual boost controller. It works but you won't have two seperate settings like an electronic boost controller. This is just a ****.
ochsy03
Mar 24, 2005 08:53 AM
Sketch_hs
Aug 10, 2004 09:06 PM
ATS*Mark
Feb 18, 2004 01:25 PM
incognitoracerr
Apr 23, 2003 06:52 AM
