Turbonetics
Old Jun 5, 2007 | 02:45 PM
dsnyder305's Avatar
Default Turbonetics
I just got a used Turbonetics turbo from eBay, and I've got a little problem. The serial #
has worn off, and I really don't know anything about it other than that it is a T3/T4 6O-1
with a .48 A/R on the hot side, external wastegate, 5 bolt downpipe flange. I need to
rebuild it before I put it in my car, and I have NO idea what compressor housing it has,
and what kind of rebuild kit you buy is dependent therein. So...does anybody know if
there are any marks, or #'s, or ANY other way to tell what kind of comp. housing it has?
Old Jun 5, 2007 | 02:52 PM
RCautoworks's Avatar
Default Re: Turbonetics (dsnyder305)
Sure its a real turbonetics turbo ?
Old Jun 5, 2007 | 02:56 PM
dsnyder305's Avatar
Default Re: Turbonetics (RCautoworks)
Says so in big block letters on the comp. housing.
Old Jun 5, 2007 | 03:31 PM
dsnyder305's Avatar
Sooo...any body know?
Old Jun 5, 2007 | 06:13 PM
under_boost's Avatar
genuine t-netic turbos have the flaming "T" insignia cast into the chra. the housings are interchangable with alot of turbos.
if you need to verify what turbo you have, measure the inducer/exducer and you will know what turbo you have.
Old Jun 6, 2007 | 05:28 AM
dsnyder305's Avatar
Default Re: Turbonetics (under_boost)
Yeah, I looked over that SOB really good last nite and found what I was looking for. If
any body had/has that same problem I did, look on the flat part of the DP flange on the
exducer of the hot side and it will be ingraved with all the info you need to know. Its got
the part#, the turbine housing STG rating, the turbine housing a/r, everything. FYI.
ef9_civic_hatch
Jun 24, 2009 06:57 PM
rippinitup01
Oct 6, 2007 01:51 PM
jononioo
Feb 1, 2006 12:00 AM
krazy
Apr 9, 2003 12:44 PM
95 LS
Apr 16, 2002 05:18 AM
