Turboing a d16y8
Old Aug 16, 2004 | 10:35 PM
g2_boosted's Avatar
Default Turboing a d16y8
Hey, I have a turbo kit for my d16Y8 on the way, its a t25 with all that other stuff blah blah blah... Im trying to figure out what to do for my fuel management.. turbo is going to be pushing out 6-7psi, I have a VAFC installed so im considering the vafc hack. what kind of injectors do i need and anybody wanna hook me up with a good deal? thanx
Old Aug 16, 2004 | 10:39 PM
Tekno9998's Avatar
Default Re: Turboing a d16y8 (g2_boosted)
I would recommend dsm 450s if you insist on the hack there cheap. But i would go with uberdata or hondata to make the most out of your setup
Old Aug 17, 2004 | 08:58 AM
RyanEJ8's Avatar
Default Re: Turboing a d16y8 (Tekno9998)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tekno9998 &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend dsm 450s if you insist on the hack there cheap. But i would go with uberdata or hondata to make the most out of your setup </TD></TR></TABLE>
I agree 100%.
Old Aug 17, 2004 | 01:41 PM
g2_boosted's Avatar
Default Re: Turboing a d16y8 (RyanCivic2000)
yeah i got the vafc so i wanna use it. Whats the difference in all the saturated and peak and hold injectors? I want something moderately easy to install and i need to know exactly what i need to get my cars fuel running properly
Old Aug 17, 2004 | 02:23 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_boosted &raquo;</TD></TR><TR><TD CLASS="quote">yeah i got the vafc so i wanna use it. Whats the difference in all the saturated and peak and hold injectors? I want something moderately easy to install and i need to know exactly what i need to get my cars fuel running properly</TD></TR></TABLE>
You need Uberdata or Hondata to get the fuel running properly. I had a VAFC and sold it. You should do the same if you want your fuel and timing setup properly.
The difference between saturated and peak and hold injectors is the resistance. If you get peak and hold injectors you will need to wire in a resistor box since the D16Y8 uses saturated injectors.
Old Sep 6, 2004 | 05:17 AM
GoneToTheDarkSide's Avatar
internals for sale... d16y8 or d16z6 along with other parts
https://honda-tech.com/zerothread?id=962350
check it out.
Old Sep 6, 2004 | 05:36 AM
93turbo16's Avatar
You can use a vafc or safc to run with some smaller injectors that 450s, with a little boost dependent regulator. That would work and not throw the timing off as much, also a MSD BTM would work, but the only thing is uberdata costs just as much as all of those things and is better.
Old Sep 6, 2004 | 05:45 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (93turbo16)
uberdata!!!
joshcivic00
Jul 4, 2005 04:13 PM
kingofkingz
May 15, 2005 08:52 PM
illestrolla247
Jul 30, 2004 07:31 AM
97coupe
10
Apr 7, 2004 02:39 AM
Spoon_Nazi
Sep 4, 2003 08:35 AM
