turbod zc
Old 01-15-2004, 07:41 AM
94blackhatch's Avatar
Default turbod zc
is turboing a dohc zc as good as turboing a ls
can the same results be reached with a zc as an ls
Old 01-15-2004, 07:44 AM
Moderator
TheShodan's Avatar
Default Re: turbod zc (94blackhatch)
hmm..
Short answer: YES w/ an "IF"......
Long answer: NO w/ a "BUT"......
I'm too tired.. so if someone here could elaborate...
Old 01-15-2004, 08:22 AM
Default Re: turbod zc (TheShodan)
i saw zcs for wicked cheap online and i was about to buy an ls but if the zc can be better then i will go for it another other input is greatly appreciated
Old 01-15-2004, 08:31 AM
Moderator
TheShodan's Avatar
It's not the internals that make it difficult, though the rods are smaller.. It's the accompanying parts that are a pain in the *** for that motor. Clutch, flywheel, and intake manifolds all come from different parts of different cars. If you ask any shop about "what about this for a ZC?" and you're outside SoCal, they're response would more than likely start out as "Uhhh....well, I'm not sure what this fits, but I'll have to call to see if its the same as a D16 or B series, and if the spline matches.. etc..
Go with the LS, you'll save more money later..
Old 01-15-2004, 10:05 AM
CRXRageD's Avatar
As a ZC owner, I will give it to you straight. Findng parts can be a pain in the ***. The block internals are easy as they are the same for most d16's. the hard parts are things like the timing belt, head gasket crank pulley, the minor wiring involved and then finding an ECU that will make run correctly (87-89 teg ECU's run rich). There is a lot of cross referencing when owning a ZC.
Try having one built. The block was built by Endyn and it's not cheap. The ECU is a Zdyne. and all the other parts to make a it a turbo car had chosen or had to be fabbed. The only turbo kit that will fit remotely close but not perfect is a greddy kit. Then you be plagued with the issue of people asking if it's an LS or "What's a ZC?"
PM me if you got questions.
Old 01-15-2004, 10:31 AM
Default Re: turbod zc (CRXRageD)
i think ill just go with my turbo ls... im going to get a drag kit as soon as i get the engine
soodominican
18
12-12-2007 12:32 AM
tigz
07-06-2004 01:40 PM
DOHC_EF
13
06-04-2004 09:39 PM
DV98CVC
01-21-2004 04:40 PM
LSVTECKING
09-10-2003 10:13 AM
Quick Reply: turbod zc
