turbo water
Old Sep 6, 2004 | 09:05 AM
thunteg's Avatar
Default turbo water
what all do you have to do when turbo's are water cooled also what extra stuff woul di need?
Old Sep 6, 2004 | 09:25 AM
pip9's Avatar
Default Re: turbo water (thunteg)
what do u mean? like how do u hook it up??
if u want u can just block off the ports for the water. Or just run lines from the coolant system to the turbo.
Old Sep 9, 2004 | 05:02 PM
deeweewoo's Avatar
Default Re: turbo water (pip9)
Where do you tap for the water source on a B18 and wher do you return?
Old Sep 9, 2004 | 05:05 PM
Gesundheit's Avatar
Default Re: turbo water (deeweewoo)
tie into the coolant lines feeding the throttle body
Old Sep 18, 2004 | 01:21 PM
deeweewoo's Avatar
Default Re: turbo water (Crankdriven)
Does it mater which way is in and which way is out? And do I just route it to my turbo then back? Thanks for the help!
Old Sep 18, 2004 | 03:24 PM
uptownrickyv's Avatar
is it any more efficient to be water cooled?
Old Oct 2, 2004 | 01:05 PM
deeweewoo's Avatar
Default Re: turbo water (uptownrickyv)
cooler turbo = cooler oil = thicker oil = less friction = longer turbo life
xineedmoneyx
Aug 1, 2005 07:08 AM
the.hamburglar
May 1, 2004 07:13 PM
You_Get_Vapors
May 4, 2003 06:17 PM
DS1
Oct 4, 2002 08:21 PM
intekragsr
Apr 15, 2002 03:58 PM
