Turbo Type R's...
Old Aug 6, 2002 | 02:08 PM
01ITR#700's Avatar
Default Turbo Type R's...
I'm in the process of turbo charging my Type R. I'm running the REV Hard Manifold and a Turbonetics 60-1 HIFI turbo. So far to get it to fit I've had to notch the block a bit and trim the fan shroud and even barely "clip" the very tip off of each of the fan blades. I know the FAL fan would have worked fine but I'm low on funding right now
I wanted to see if that seems to be normal for other boosted Type R's.
Thanks.
M
Old Aug 6, 2002 | 02:44 PM
Etylorcen's Avatar
Default Re: Turbo Type R's... (01ITR#700)
Normal for all integs.
Old Aug 6, 2002 | 07:06 PM
ninetyfourgsr's Avatar
Default Re: Turbo Type R's... (Etylorcen)
yep i trimmed my fan blades a bit too
Old Aug 6, 2002 | 07:10 PM
uNF$@#!'s Avatar
Default Re: Turbo Type R's... (ninetyfourgsr)
are you guys running your turbos on a stock fuel system?
Old Aug 6, 2002 | 07:48 PM
scooter's Avatar
Default Re: Turbo Type R's... (Soup ****)
Any R's out there running on stock internals and stock head gasket? who's been doin it the longest?
scott
Old Aug 6, 2002 | 08:09 PM
nekkedR's Avatar
Default Re: Turbo Type R's... (scooter)
im runnin the stock head gasket and compression, i havent driven the car yet cause im waiting for my hondata 2b to show up. but if i throw a rod on start up i'll let ya know
Old Aug 7, 2002 | 07:09 PM
turbotypeR@SPEC's Avatar
25 Year Member
yeah,that sounds normal.buy spal fans.they are only 2" deep and are much better than fal.only$200
Old Aug 7, 2002 | 07:21 PM
DC2R714's Avatar
Default Re: Turbo Type R's... (turbotypeR)
I been running stock headgasket/ stock compression 7psi for almost a month no problems.
Old Aug 8, 2002 | 06:29 AM
fast[R]'s Avatar
Fall fan's I had to put one in because the intake pipe for the filter would "NOT" fit at all
Old Aug 8, 2002 | 06:37 AM
1.8TypeR's Avatar
Default Re: Turbo Type R's... (fast[R])
stock c/r, stock headgasket, daily driven for 8k+ miles @.45bar with no problems.
Old Aug 14, 2002 | 08:45 AM
01ITR#700's Avatar
Default Re: Turbo Type R's... (1.8TypeR)
Thanks for the info guys.
My little project should be done here in the next week or so. And yes I'm going against all that is holy and running a stock block, head gasket etc. and a .45 bar spring
M
DrewBrews
13
Dec 21, 2011 08:33 AM
gsrjdm00
Mar 22, 2009 03:28 PM
afmoose7
Apr 18, 2006 09:47 PM
B16Drag
Apr 16, 2005 06:02 PM
metal-x
Jul 15, 2003 05:12 PM
