Turbo Type-R what to do?
Old Nov 13, 2002 | 05:25 PM
revhigh96's Avatar
Default Turbo Type-R what to do?
I am interested in putting a turbo on my B18C5. I have the engine in a 96 EX coupe. I know many people say to go all motor but the swap is done and I want a turbo so please no negative comments about it. I have looked into DRAG turbo kits and that is what I am thinking about doing. I have quite a large buget so I want everything done right. I am wondering what electronics to go with also.
Old Nov 13, 2002 | 05:33 PM
falcongsr's Avatar
What is this crap?
Default Re: Turbo Type-R what to do? (revhigh96)
define "quite a large budget"
what are your goals?
Old Nov 13, 2002 | 05:36 PM
revhigh96's Avatar
Default Re: Turbo Type-R what to do? (falconGSR)
I am looking to spend about 7,000 just to get started with my turbo system. There really isnt a limit in the end. I am looking to run a mid 12.
Old Nov 13, 2002 | 05:53 PM
turbod16y8's Avatar
you will achieve your goal easily with 7,000 in turbo parts
Old Nov 13, 2002 | 06:07 PM
B18PoweredCivic's Avatar
Order an Apexi Kit from Japan and do a block guard..Thicker head gasket to drop Comp. and Hondata..That should all run you about 5..I garuntee you'll do mid 12's at 10-12 psi
Old Nov 13, 2002 | 06:13 PM
MiraiZ's Avatar
Default Re: Turbo Type-R what to do? (B18PoweredCivic)
$7,000 sound about right....since you have a hybrid...I would go custom, and by parts from different manufacturers...
Old Nov 13, 2002 | 06:21 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Turbo Type-R what to do? (MiraiZ)
Well, if you want to run mid to low 12's, and have a budget of 7k, you could easily run that number and retain some reliability, and maybe even have soem money left over... if you are interested in the drag kit, then go ahead and purchase that, purchase an inline pro head gasket, and get a clutch and slicks, that should be enough for 12's right there IMO, and its not that complex, its probly the easiest way for soemone just getting into a turbo car...good luck..
EJspoon
Aug 12, 2004 01:36 AM
BANting
Oct 13, 2002 12:29 AM
Turbo Powa
Jun 7, 2002 06:21 PM
1sick4door
Feb 27, 2002 02:13 PM
Blown4-Banger
Nov 26, 2001 09:34 PM
