turbo for type r ?????
Old Apr 27, 2002 | 05:21 PM
vteckiller's Avatar
Default turbo for type r ?????
what is a good turbo for the type r whch will cost a decent price for a high compression engine 10:6:1
Old Apr 27, 2002 | 05:35 PM
MiraiZ's Avatar
Default Re: turbo for type r ????? (itrfreak)
there is no such thing as a decent priced turbo...look to pay about $6000 at least at the end of the day... DRAG, FMAX,REV HARD, GREDDY, APEX'I, TOP FUEL...all make kits for the Integra...for the R, you may need to fabricate parts on some kits, but all of the fudemntal parts from a GSR will fit...
Old Apr 27, 2002 | 07:08 PM
uNF$@#!'s Avatar
Default Re: turbo for type r ????? (MiraiZ)
6000?
wheres the other 3500 go?
Old Apr 27, 2002 | 07:15 PM
MiraiZ's Avatar
Default Re: turbo for type r ????? (00-0187)
well...if you want a solid system, you will want a stand alone fuel system ($1000-$2500 depending on the type), larger injectors ($100-$500), some kind of detonaton solution ($150 for a simple timing retard type of device to $1000 for a set of low compression pistons, which is always best).
You can always just install the kit as-is...but you can ask anyone here, you will always want more later, even if you think you don't now, you will be forced to...more power=more money ...at the end of the day, unless you have the know how to do a Home Depot job on your parts...your install will cost a lot more than just the kit...
[Modified by MiraiZ, 2:34 PM 4/28/2002]
Old Apr 27, 2002 | 07:58 PM
Type-ARR's Avatar
6000?
3500 for an R turbo.........your kidding right?
Old Apr 29, 2002 | 11:35 PM
itr501's Avatar
Default Re: turbo for type r ????? (TurboR481)
What about if I only wanted about 7 lbs of boost on stock internals. Then, shouldnt I be able to pick up a kit or piece my own for around 3k and install it myself?
Old Apr 29, 2002 | 11:45 PM
intekragsr's Avatar
Default Re: turbo for type r ????? (itr501)
You arent going to just want to run 7 pounds when u get your turbo running......its a sickness that everyone gets once they booooost
Old Apr 29, 2002 | 11:51 PM
G_Man604's Avatar
Default Re: turbo for type r ????? (intekragsr)
don't ever cheap out on your type r when runnin' boost...bad things will happen
Old Apr 30, 2002 | 12:28 AM
austrian type-R's Avatar
Default Re: turbo for type r ????? (G_Man604)
Yeah, right. For an kick *** setup you need at least 7000 USD. Think about you need exhaust, injectors, fuel pump, standalomne and stuff too.
Old Apr 30, 2002 | 01:36 AM
MiraiZ's Avatar
Look to pay a LEAST $6000 fo a safe setup ...I wouldn't fabricate any fuel solution on an R...go stand alone, or you will be paying much more for repairs in the future.
[Modified by MiraiZ, 7:46 PM 4/30/2002]
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: turbo for type r ????? (austrian type-R)
Don't forget the cost of TUNING and INSTALLING IT!
That could be close to another grand.
Old Apr 30, 2002 | 04:33 AM
TurboSohc's Avatar
Of all things pick atleast the hondata up with the turbo
Old Apr 30, 2002 | 04:36 AM
MiraiZ's Avatar
Default Re: turbo for type r ????? (TurboSohc)
need injectors with that!!.....stock injectors won't cut it...not even at 5psi!...so that's like $1200 to $1500 n top of the turbo kit already....what are you going to do to lower the compression?? That's a must too!
[Modified by MiraiZ, 10:37 PM 4/30/2002]
L2000S
Aug 12, 2017 06:39 AM
Zombie Nachos
12
Jul 15, 2010 11:14 PM
Coroner
Mar 21, 2006 09:04 PM
subydoored
Apr 18, 2005 07:15 PM
Sparco_TypeR
Apr 29, 2003 02:31 PM
