Turbo Timer Noob Question...difference between accessory and Ignition?
Old Sep 5, 2007 | 08:13 AM
StreetEG's Avatar
Default Turbo Timer Noob Question...difference between accessory and Ignition?
Tried seaching but cant find it...and I feel like a jackass for asking-- but I am running the blitz turbo timer in an OLDDDD Z and I am having probs with it activating the starter when I turn the car off---
The only thing I can see is that the "ignition" and "accesory" wire are coming off of the same connection on the steering column....
What is the purpose of each wire in relation to wiring to timer?
Old Sep 5, 2007 | 08:58 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Turbo Timer Noob Question...difference between accessory and Ignition? (StreetEG)
ign is everything hot ecu powered up. accessory lets you turn the accessories on w/o the ecu being on.
the tt needs the ign to see voltage and it is there when the key is on and past accessory. but when the key is out, the switch passes the acc position, and opens the contacts. the tt has the accessory go through it to keep the car running.
Old Sep 5, 2007 | 03:30 PM
StreetEG's Avatar
Default Re: Turbo Timer Noob Question...difference between accessory and Ignition? (boostedcivicsir)
that was awesome thank you
integrax97
Jun 19, 2007 07:03 PM
jBj
Aug 19, 2006 06:53 PM
SolidSpruce
May 6, 2002 06:59 AM
