turbo timer, boost controller, and 2 gauges = accessory power????
Old Jul 3, 2004 | 10:30 PM
tyflip2's Avatar
Default turbo timer, boost controller, and 2 gauges = accessory power????
i have a boost gauge, air fuel gauge, turbo timer and boost controller all soldered up to the accessory on the ignition area under the steering wheel. my question is is that ok to have so many things hooked up to that one spot? i have started the car and everything seems normal but i just dont want to short anything. i know the gauges dont take too much power but i need any help. thanks alot
Old Jul 3, 2004 | 11:10 PM
tyflip2's Avatar
Default Re: turbo timer, boost controller, and 2 gauges = accessory power???? (tyflip2)
bump before bed
Old Jul 4, 2004 | 01:36 AM
LBR92DA-T's Avatar
run it from the acc power from your deck but fuse it just in case... a low amp fuse maybe 5.. just a thought.. it would be the red wire on your aftermarket deck harness...
da_ska
May 31, 2009 07:24 AM
turbohatch96y7
May 24, 2009 10:58 PM
dinosa21
Nov 8, 2002 08:21 PM
grnsol
Feb 22, 2002 06:35 PM
txhatch
Jan 31, 2002 06:44 PM
